Thread: Wanted circuit diagram SB11 BA11-VA shoe box, particularly for PSU
    Question Wanted circuit diagram SB11 BA11-VA shoe box, particularly for PSU
    I have an old SB11-AA, BA11-VA shoe box, H9281 card frame, I can't find the psu model only Digital AB04409CY6 which I presume is the sn. The PSU is u/s does anyone know where I can find the circuit diagram and specs for the PSU?
    At present I have the card cage and backplane out on the bench connected to an old PC psu, 13A +5v, 3 A +12v.
    I have tried a few searches but very little seems to be available.
    Thanks
    Peter
    Liverpool, England
    325
    I have just acquired three of these, one is a DEC original with no card cage or cards and the other two are clones with an RS PSU and a DEC card cage but no cards. I don't have any documentation though.
    Sep 2016
    Westminster, Colorado
    35
    I doubt DEC ever published the schematics for the PSU, but it should be a standard switching supply, so it shouldn't be hard to reverse. Wiki
    I'm not sure what you mean by "The PSU is u/s", but the old supplies would not work without sufficient load, to the extent that uVAX expansion boxes had a resistor dummy load board paired with the TK50 drive to keep the PSU in spec. About 3 ohms on the 5V and 12 ohms on the 12V supplies. Modern switching supplies are much better about handling no-load conditions.
    I've got a number of shoeboxen collecting dust, but the UK is a little far to ship...
    From the Digital Microcomputer Interfaces Handbook:
    5.6 amps at +5V max
    1.6 amps at +12V max
    CW
    Liverpool, England
    325
    I have cleaned my ba11-va and the two clones. I've tested the PSU's for output only no load or ripple test yet. All three fans are quiet. I've moved the backplane from one of the clones to the original DEC BA11-VA.
    I'll check the PSU for ripple next and insert a board to see PSU under load.20170811_091525.jpg20170811_091528.jpg20170811_091537.jpg
    Liverpool, England
    325
    I have tested these with just a DLV11-J installed and PSU's seem ok. This possibly isn't the place but I'd like to swap the two clone BA11-VA only one H9281 backplane though for a KDF11 and (cheeky!) MSV11 with a UK member if possible. Thanks.
