Results 1 to 6 of 6
Thread: Floppy compatibility with Tandy 1400 LT
    Default Floppy compatibility with Tandy 1400 LT
    Hey I have a Tandy 1400 LT and have the standard floppys that run on it:
    MS-DOS/GW-BASIC Operating system
    All three DeskMate diskettes
    Are there any other floppy disks that would run on my Tandy?
    Thanks for any help
  2. Default
    Would a regular dos on a bootable 720K work? I think the 1400 wasn't too bad compatibility wise when you stuck with text.
    Most XT and CGA compatible software will run.
    In case you feel ambitious: https://www.lo-tech.co.uk/product/tandy-1400-xt-cf/
    Hi,
    do you still have these disks now? Could it be possible by any chance to image them and email them to me?
    I got a 1400 LT hardware, but still need the proper system disks to boot it.
    thank you
    Sep 2009
    Lincolnshire U.K.
    113
    There's also an article in the Dec 2017 edition of TRS8BIT (trs-80.org.uk) re using a modern SD type card.
    Is there an easy way to tell what software will work on it? Don't want to get software that might not work.
    P.S. No, I do not have the ability to image the disks. Sorry
