Results 1 to 10 of 10
Thread: Mac LC 575
    Default Mac LC 575
    Greetings! This I am writing to find more about my Macintosh LC 575. My knowledge is limited to; A: The business model of the 575 is called the Peforma 575. B: The location I received it from apparently had a huge stockpile of these things. They have probably thrown all of them away by now. (It was a school) And C: Some nitwit stuck a foreign object (such as a cookie or a piece of paper) in the built in FDD. It doesn't even let the disks enter because the drive moved. It also has a CD/DVD drive which works fine for media, but stutters with music. It also has a few games such as: Helicopter Lander, Factory, A clone of asteroids and some other games. It also has a few teaching and productivity applications such as a calendar, test score form creator, and a word processor. Once again, if anyone knows about any info about this system, please reply to this thread.
    Best Regards,
    Owen Stevens
    040 based 33mhz CPU, probably a 2x CD-ROM. Should support up to MacOS 8.1. LC expansion slot which you can use to add ethernet if it doesn't already have it.
    The Performa line was actually targetted more at home and non-professional consumer users as "budget" versions. The 575 is a decent 68K, though. You can find out what OS it's running from the Apple menu and select About This Macintosh.
    I use my C128 because I am an ornery, stubborn, retro grouch. -- Bob Masse
    Machine room: http://www.floodgap.com/etc/machines.html
    OK! Thanks for the help!
    That link wants a Google sign-in.
    Dec 2014
    Sol->Earth->North America->USA->CA
    73
    I get a 404 with that link
    Whoops. I forgot about that stupid sign in thing. I will try again.
  9. #9
    Jan 2010
    New Zealand
    3,110
    4
    It works for me.
    Thomas Byers (DRI)- "You'll have a million people using the A> [MS-DOS prompt] forever. You'll have five million using [nongraphic] menu systems such as Topview, Concurrent PC-DOS, Desq, and those types. But there'll be 50 to 100 million using the iconic-based interfaces."
  10. #10
    Something you may not have noticed is that it has a Trinitron CRT. The 575 is the best of the 68k all-in-ones. There was a later model (the LC580) but it changed the hard drive interface to IDE and lost the Trinitron CRT for a ordinary shadow mask tube. They have a 68LC040 (no FPU) but you can swap the processor for a full '040 if you wish.
