Results 1 to 8 of 8
Thread: Looking for Toshiba T3100e floppy disks.
    Jan 2017
    Default Looking for Toshiba T3100e floppy disks.
    Hi,
    I'd like to restore my Toshiba T3100e to it's factory state, but don't have the associated floppy disks. It's currently running MS-DOS (Toshiba version) 4.0.
    If anyone has the disks and are willing to make copies, I'd be happy to pay for media and postage.
    Thanks.
    6,605
    Welcome to these forums.
    According to the T3100e flyer at [here], the T3100e was supplied with DOS 4.01, with 3.3 being an option.
    The Toshiba document at [here] also indicates 3.3 and 4.01 for the T3100e.
    Are you seeking DOS 4.01 (Toshiba version) floppies ?
    Jan 2017
    Default T3100e floppies.
    Thank you for your reply to my post. Yes, I am seeking the DOS 4.01 (Toshiba version) floppies. I have recently acquired a T3100e, and would like to wipe the hard drive and restore it to it's factory state.
    Dec 2005
    Toronto ON Canada
    7,342
    Quote Originally Posted by Chris42 View Post
    I've got a 3100e that I bought brand new, so I should have the manual and disks somewhere; can you make disks from an image and if so, what imaging program?
    Send me a PM.
    FWIW I dumped 4.01 and use 6.22 instead.
    m
    Dec 2005
    Toronto ON Canada
    7,342
    While I'm looking for those disks you might find this thread interesting:
    http://www.vcfed.org/forum/showthrea...Memory-Upgrade
    m
    6,605
    720K sized images can be found via a Google search using: MS-DOS 4.01 Toshiba
    Dec 2005
    Toronto ON Canada
    7,342
    Just found mine, but looks like you're da man as usual!
    If/when I find the user manual, is it already on line somewhere?
    m
    6,605
    I haven't seen it, but then, I have not spent the half hour that is sometimes required to find things online.
    Some links that I see for a Toshiba laptop user manual is actually pointing to the maintenance manual.
    If you are willing to scan the manual, I will host it at [here].
