Results 1 to 10 of 14
Thread: IBM PC-Retro Kit IBM 5150 SuperSoft 8237A Failed
    Jan 2017
    Zürich, Switzerland
    17
    Default IBM PC-Retro Kit IBM 5150 SuperSoft 8237A Failed
    Hello
    I just completed the PC-Retro Kit a few hours ago. Now I tried to start it (Just see if it passes the BIOS POST because I have now floppy controller and no XT-Keyboard at the moment).
    The board starts and shows the bios screen followed by a short beep, then it types that there is no floppy in Drive A:.
    I then switched U33 to the Siupersoft POST Diagnostic to be sure everithing is right. But it displays me a whole lot of errors.
    It fails the
    • 8237A DMA test
    • the keyboard controller,
    • (as expected the floppy controller)
    • system memory at adress 32322 (with all failing bits except the 0th)
    • slow refresh to A0000
    Im not entirely sure if it is ok if it fails the memory tests, because in the manual the super soft screenshot shows these tests as failed too.
    I have an CGA card installed and 64k (one bank) of memory.
    I tried to refit the 8237A two times but with no success.
    Thanks for your help.
    Thomas
    6,531
    Quote Originally Posted by ThommyThomaso View Post
    Hello
    Welcome to these forums.
    ... the keyboard controller,
    Note that the KEYBOARD CONTROLLER test does not test the keyboard controller. Why? Because the IBM 5150 (which the PC-Retro Kit is a clone of) does not have a keyboard controller chip. The KEYBOARD CONTROLLER test is a test of the keyboard interface circuitry and the keyboard.
    ... and no XT-Keyboard at the moment)
    In the IBM 5150, the KEYBOARD CONTROLLER test is known to fail if there is no XT-class keyboard attached. So you need to wait until you get an XT-class keyboard.
    ...system memory at adress 32322 (with all failing bits except the 0th)
    ...slow refresh to A0000
    Note that in the IBM 5150 (which the PC-Retro Kit is a clone of), the two RAM switches on motherboard SW1 do not enable/disable RAM banks. Those switches inform the BIOS as to how many banks are populated.
    The Supersoft/Landmark ROM ignores the switches. It expects all 4 banks of RAM to be populated. That is probably why the Supersoft/Landmark ROM indicates a RAM error, but the Anonymous BIOS does not.
    Populate all 4 banks of RAM, then see if the Supersoft/Landmark ROM indicates a RAM error.
    ...8237A DMA test
    A faulty 8237A is a possibility.
    The PC-Retro Kit has over 2000 solder joints. I think that you should get out a magnifying glass and check all of the joints very carefully.
    Jan 2017
    Zürich, Switzerland
    17
    I have ordered the parts to build the AT2XTKB adapter, so I should have a Keyboard by the end of the week.
    I already thought that the Supersoft ROM might check the Keyboard itself. And therefore report a failure.
    I have ordered full 256kb ram so I will later populate all 4 banks and try the Supersoft test again and see what will happen. I was a bit frightened that the DMA failure could also cause that the RAM refresh cirquitry will fail and therefore all the DRAM errors occure. But on the other hand if the RAM refresh does not work properly the Anonymous BIOS would report that, wouldn't it?
    I'm still a bit confused that the BIOS won't notice a fault in the 8237A. I mean accourding to the technical manual the DMA Controller gets checked on POST. Could it be that the 8237A failure reported by the Supersoft could be a result of a missing Floppy controller? I have an WD Floppy/Winchester controller but it seems as it won't work. The BIOS will just show a flashing cursor if I plug the card in. So I try to test the mainboard with only a graphics card installed.
    I already checked all the joints twice while soldering, but I certainly will recheck them all with a magnifing glass later. Do you have an idea where I could find a spare 8237A? I mean if really mine would be faulty I would have to find a replacement.
    6,531
    You should not read "checked" as "100% checked".
    Checks done by the POST are usually very basic, both to speed the boot process, and because of limited space on the ROM.
    These are only confidence checks.
    The POST in different BIOS' will check various bits to varying degree - it is up to the BIOS author.
    For thorough hardware testing of an IBM 5150, IBM supply diagnostic floppies.
    If the 8237A was 'dead', of if the 8237A (or supporting circuitry) was such that the 8237A was 'unreachable' by the Anonymous BIOS, then yes, you would expect the Anonymous BIOS to 'complain' about such a basic problem. But maybe the 8237A problem (if there is indeed one) is not basic.
    For the IBM 5150, no floppy controller is required for the 8237A test. The test passes.
    * Faulty controller ?
    * Floppy controllers use DMA (i.e. 8237A) !!
    One would expect (repeat: expect) that if RAM refresh was not working properly (or at all), that the POST in the Anonymous BIOS would report a RAM error when it did its crude RAM test.
    If you had BASIC chips, you could experiment by entering a few lines of BASIC program, then seeing if it was still present 5 minutes later.
    To be noted is that RAM refresh only uses one channel of the 8237A.
    Did MTM Scientific indicate that the 8237A would have been tested prior to dispatch ?
    eBay will have the 8237A (but will it be tested!)
    Some possibilities that I can think of:
    * Faulty kit assembly
    * Faulty 8237A
    * Faulty circuitry associated with the 8237A
    * False alarm by the Supersoft diagnostic ROM. Do other BIOS' indicate a DMA problem ?
    In the end, diagnosis may require the (skilled) use of test equipment such as a logic probe and logic state analyser.
    Jan 2017
    Zürich, Switzerland
    17
    Ok thanks. I couldn't find this piece of information in the manual.
    I have checked the controller in my 386 and there both winchester and floppy part of the controller worked. But maybe it isn't jumpered right for the 5150. I haven't found any manual yet for the controller. So I just leave the default jumper position.
    I thought about that a really faulty DMA would give some problems with the floppy controller. But as far as I understood it, the initialisation of the drives works through ordinary registers. So I'd guess the Floppy card and drive would at least get a reset, but its just dead silent. So I assume the controller is not properly jumpered.
    I will burn the basic chips as soon as possible. Its just I first need some adapters. I just have 27Cxx laying around.
    I wrote an E-Mail to MTM and asked if they have encounterd such an error before.
    Sure. thats an issue I havent thought about.
    I will check out the technical manual and try to check the solder joints and the IC's. I have the equipment to test some simpler IC's but unfortunately I'm not that well equipped here.
    I will ask some people at school if I could get access to some testing equipment.
    I will burn the original IBM Bios to a 27Cxx and see how it wil react. Also I saw there is a whole series of Testing roms on the support CD. I will burn those and see what they will report.
    Thank you for your assistance. I really was as careful as possible when soldering the board and placeing the IC's. I really hope that in the end the board will work properly.
    6,531
    The adapters that I have seen are wider than the ROM sockets.
    There is one more possibility that came to mind. You may have been supplied with a faulty circuit board. I have not been involved in modern circuit board production and so I do not know what the likelihood of a faulty board is. I think that it would be pretty low, but a possibility nonetheless.
    All of the chips are socketed. Potentially, MTM Scientific could loan you set of working chips for diagnostic purposes.
    Jan 2017
    Zürich, Switzerland
    17
    I would solder one adapter for all 4 chips. As far as I understood it just switches a few lines and pulls the unused adress pins high.
    I think chances are much higher that ether a chip is faulty or I really have messed up one solder joint. I mean just because I see no bad solder joint doesn't mean there is none.
    I wrote MTM Scientific but I still wait for an answer. I think that would be the easiest way to go. Switch the DMA with a confirmed working one.
    4,796
    I should think they would be e-testing a board that complex. Even the XT-IDE rev 3 boards get an e-test!
    6,531
    Until your post, I had never heard of an "e-test" for PCBs.
    According to the web page at [here], the "flying-probe" type of e-test is not flawless.
    33,656
    If the 8237A is a complete and utter washout, DRAM won't be refreshed. That should manifest as a whole pile of issues.
