Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: PC Speaker (Square Wave) Sound Effects
  1. #21
    Well, okay, in my experience anyway (but I only ever tried it on one system with a piezo beeper, so take that with a grain of salt.)
  2. #22
    Quote Originally Posted by neilobremski View Post
    Thank you Krille for the Magic Duck stuff. Could you tell me offhand how fast the frame rate is when you run aSoundPlay?
    I have no idea, I haven't tried it. TBH, I haven't even tried MagiDuck yet. Though I imagine the difference should at least be measurable since this routine runs once every frame.
  3. #23
    It's called at 24 frames per second. If a frame render takes longer than 24hz the sounds slow down with the framerate, which I suppose works well for sound effects but would not for music.
  4. #24
    I have two 8088 clones with piezos on them, I could do some recordings.
    I'd be curious to hear this!
  5. #25
    5,014
    My 6300 had a piezo; it sounded very thin and tinny and quiet, but was otherwise identical to a regular speaker -- all tricks worked, all sampled sound output methods worked. You just had to put your ear to the machine to hear it sometimes.
    I later broke the speaker off of the system and connected two wires to the pads which I then wired to a 3.5" jack that went to my boom box.
    - A working Sanyo MBC-775
