Results 1 to 10 of 15
Thread: Tandon TM848-2 fuse
    Jan 2012
    Zurich, Switzerland
    281
    Default Tandon TM848-2 fuse
    I have a Tandon TM848-2 8" floppy drive where the fuse next to the power connector has blown. No idea yet where the cause is, but I can find no info on the rating of the fuse, and it doesn't appear on the schematics, at least that I can find. Does anyone know what a suitable replacement would be? I read in the specs that there can be as much as 2.5 amps drawn on the 24v line as the spindle motor starts, so in the absence of any further info, I've found some 4A slo-blow axial fuses. Does this sound reasonable?
    cheers, Rob
    Dec 2005
    Toronto ON Canada
    7,342
    Quote Originally Posted by crock View Post
    cheers, Rob
    Hi Rob,
    Only two out of my four TM848s actually have that fuse installed and it certainly looks like an afterthought; FWIW it is a BEL 3A, no indication to suggest that it's an SB type.
    m
    34,138
    One of the reasons that the fuse on the 848 can blow is that the 4.7uF cap C6 can short or the 7812 regulator that follows it has failed. You might also check out the 4.7 uF cap at C2. I've had drives fail twice because of the 7812 being run too hot. It's a lousy design and probably an afterthought. If you have a separate 12V supply, you may want to consider bypassing the regulator entirely.
    Consider, at a draw of 2A, that regulator has to dissipate 24 watts in heat!
    A more pragmatic approach would be to use a "simple switcher" to drop the 24V. Such as the LM2576, which would take a few more components, but eliminate that hot spot.
    Jan 2012
    Zurich, Switzerland
    281
    You were bang on the money Chuck, the C2 capacitor was shorted. That's been replaced and the fuse bypassed and the drive at least runs now. It's still not able to format a disk yet, but I suspect that might be the controller board.
    34,138
    Just curious--did the bad capacitor have a yellow jacket? Mine did--and I'm wondering if that's one of the first things to replace.
    6,606
    I do not know which model of TM848 that you have, but the photo at [here] shows a particular make/value cap that I often found faulty when diagnosing my newly acquired TM848's. On careful inspection, some were visibly leaking. I ended up just replacing them all.
    34,138
    Got photos of C2 and C6? Those are the ones most prone to failure, it seems.
    6,606
    [Here].
    C1 was what went short circuit on one of my drives.
    34,138
    I guess it's safe to posit that if you've got a problem with an 848, the capacitors might be the first place to check...
    Jan 2012
    Zurich, Switzerland
    281
    Nope, black bullet shaped ones. Here's photos of the failed caps and fuse, plus my ugly repair until I receive some axial 4.7 uf caps.
