Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Flushing the cache
    Mar 2009
    Pleasant Hill, CA USA
    2,462
    Throes.
    No, I meant they are physically tossing IE to it's death. Bill and Steve are on the roof now, with Satya is standing behind them with a knife...
    Sep 2008
    Walled Lake, MI
    3,162
    6
    I guess just about every has been covered in this thread; particularly politics . Any new or creative ideas on flushing caches?
    Mar 2009
    2,462
    Quote Originally Posted by Agent Orange View Post
    Not sure there is a more creative way to flush DNS cache other than ipconfig /flushDNS, if you are on a mac running OS X then you'd run sudo dscacheutil -flushcache;sudo killall -HUP mDNSResponder and I am not sure about the linux command to do it.
    Quote Originally Posted by lutiana View Post
    OK but since I do occasionally listen to NPR, your grammar is still wrong.
    Be polite and I may let you live.
  5. #15
    Sep 2008
    Walled Lake, MI
    3,162
    6
    I'm still having some problems with streaming FoxNewsGo. It seems I have to flush the cache each and every time I open the site. I log in via Google+ and it seems to work okay after the flush. I think there is a problem on the Fox network side judging by the number of complaints.
  6. #16
    Mar 2009
    2,462
    Try it in an incognito window. If the issue goes away then you'll need to look at deleting cookies and/or browsing history.
  7. #17
    Sep 2008
    Walled Lake, MI
    3,162
    6
    I'll give that one a shot.
  8. #18
    Sep 2008
    Walled Lake, MI
    3,162
    6
    Ingog does work but you have to jump through some hoops. It requires you to logon through a provider; i.e. Directv, AT&T, etc. You won't be able to get in simply by clicking on a shortcut. Also, not a cookie problem, already been that route. I'm convinced it's a Fox problem by the number of people complaining about it. BTW, there's a host of 3rd party providers that will stream Fox news, but many are not in HD. Maybe it's just as easy to flip the tv on, but not nearly as convenient at times.
  9. #19
    Don't know if it helps, firefox has a handy dns flusher extension.
