Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Sage & Stride Users
    Mar 2013
    Chaffee, MO
    1,133
    Plasmo,
    I typically pick a long text or asm file such as Dump.asm or Format.asm, and have a quick look at all the
    source code, making sure it's sane and ends properly. That makes sure my definition has grabbed the
    proper bytes/sectors to create a proper source file.
    Glad it worked for you.
    Larry
    Here is a 'not all but useful' reconstruct of the "www.sageandstride.org" from the webarchive
    http://oldcomputers.dyndns.org/publi...org/index.html
    and here zipped. http://oldcomputers.dyndns.org/publi...ide/index.html
    A lot of files from the ftp downloads @sageandstride.org are missing but I hope someone will send them to me.
    As I knew one SAGE from stephan is working now and 2 other boards will hopefully be repaired next try this summer.
    Just wanted to bring this thread again up... Maybe there are meanwhile new Sage owners around?
    Sadly I do not have a Sage. Passed on a 100$ USD Sage-II some 15 years ago " I'll find a cheaper one".
    And I did find, some years ago an ad "Free to good home : Sage IV, with terminal, disks and terminal". Even local to me....
    Mailed the guy : " sorry, that ad is 3 weeks old and I chucked it in the meantime....." Sigh......
    But the machine has excellent docu available : should be a nice target for a retro-build.
    Jos
