hello
today i started out , thinking about writing , going back from Cyrix5x86 to IBM486BL due to the slow speed of the Cyrix.
And i did test the Cyrix (no cache) then the 486BL with cache and both at 50Mhz speed. The later did very well the first not so good.
And here a great thanks to stynx , for sharing the transcomputer driver tool , that enables the cache - it works and the result is a PC running at mind blowing high speed !
(most admit , did test the encache.exe for the first time today - had planed to test it earlier , but first go around to try it out today)
Today i did test the Cyrix5x86(no cache) then IBM 486 BL and last the Cyrix 5x86 with cache on.
I did use the speed test from
http://www.philscomputerlab.com/dos-benchmark-pack.html
...it states:
At the end of the benchmark you will see a value for realticks. To workout the FPS you need to use this formula:
FPS = 74690 / realticks.
and the speed with 486BL in DOOM is notisable faster the Cyrix with no cache.
My DOOM test results:
ibm 486bl 50Mhz
small window 74690/3265 = 22,8 fps
maximum window 74690/11757 = 6,3 fps
cyrix5x86 at 50Mhz no cache
small windows 74690/11591 = 6,44 fps
maximum windows 74690/49193 = 1,52 fps
cyrix5x86 at 50Mhz with cache on
small window 74690/2757 = 27,01 fps
maximum windows 74690/10229 = 7,30 fps
( the demo runnning at 7,3 FPS looks very impressive )
I also did a Winstone94 test :
IBM 486BL at 50 Mhz : score 12,1
5x86 with cache on : Score,"13,33778"
other testresults:
and topbstub data , with cache on:
;Data collected by: TOPBENCH | Benchmark and detection stub | Version 0.97
;This file contains fingerprinting information about your computer. Please
;email this file to trixter@oldskool.org with a subject line of "Benchmark" to
;help test these routines and seed the TOPBENCH database.
[UID745019165]
MemoryTest=157
OpcodeTest=154
VidramTest=1180
MemEATest=163
3DGameTest=92
Score=36
CPU=Cyrix 5x86-S (clock x3 mode)
CPUspeed=80 MHz
BIOSinfo=unknown
MachineModel=0000
BIOSdate=20120502
BIOSCRC16=7450
VideoSystem=VGA
VideoAdapter=VGA, unknown Chipset, 256kb Video Memory (BIOS)
Machine=PC
Only thing about the encache.exe is , -i think- it makes the CPU unaware of what DMA does to ram. After enable cache the floppy "dir" did look like this
... have only to say, the 486BL is nice and fast, but the Cyrix586 at 50Mhz and the cache enabled, is just mind blowingly fast! And the Cyrix will not be replaced in near future
* a hardware note - my Inboard386 board were running at normal 16Mhz and not overclocked.
/cimonvg
