Results 1 to 10 of 30
Thread: Cleaning sticker residue from EPROM chips (which solvent?)
    Question Cleaning sticker residue from EPROM chips (which solvent?)
    I just finished taking the stickers off of 22 AMD Am27C010 -120 EPROMs. Didn't get everything, and there is some adhesive residue left.
    What common products will remove the residue?
    I'd try 91% isopropyl...
    Quote Originally Posted by chulofiasco View Post
    Seconded. Use a q tip and be careful to avoid any markings.
    27,303
    My first try would be paint thinner (mineral spirits), then perchloroethylene. Since windowed EPROMs are cerDIP packages, you can't really hurt them.
    Sep 2003
    Ohio/USA
    6,691
    Goo Gone works for me (mostly stickers on laptops), made from petroleum distillates and citrus.
    I use these for everything:
    https://www.amazon.com/B-D-326895-Al.../dp/B0010L6H1Y
    pre packaged alcohol pads. THICK, and absorbent. I get mine at my local pharmacy for slightly less. Honestly 70% alcohol works just fine.
    It is a mistake to think you can solve any major problems just with potatoes.
    3,944
    Isopropyl alcohol, apply with whatever. The markings on CERDIP should be unaffected. I often just clean the window, that's really the only part where it matters, and the quartz is usually slick enough that any residue comes right off.
    Exclamation
    Hi test alcohol? You mean this bottle of 151 Rum can be used externally?
    Quote Originally Posted by ardent-blue View Post
    I've been known to buy everclear for use as a degreaser instead of for drinking.
    Hamilton, Ontario, Canada
    3,697
    I just use (carefully) WD-40 and a qtip.
    Legacy Computers and Parts
