Results 1 to 7 of 7
Thread: Serial mouse for pentium
    Jan 2015
    Hebron, Boone Township, Porter County, Indiana, USA
    205
    Default Serial mouse for pentium
    I need a serial mouse. Mobo does not have a PS/2 Mouse port, just a DIN for keyboard, as it is AT form factor. Anybody have a serial mouse I can have ?
    Sep 2003
    Ohio/USA
    6,697
    Mar 2009
    Pleasant Hill, CA USA
    2,490
    Yes - https://airtable.com/shrA7cS5ApaOun6gd
    There are a few on there with pictures. Prices are negotiable.
    Quote Originally Posted by flashedbios2012 View Post
    Check your manual. Many Pentium mobo's have an open socket with 5 or 6 pins near the keyboard port on which you can plug a PS/2 mouse adapter like this:
    https://www.altex.com/5-Pin-to-6-Pin...2-P139177.aspx
    You may have to re-wire the black connector, there is no universal system in place.
    Jan 2015
    205
    there is one of those but not only do I not feel like cutting up wires and twisting them together (I never did learn how to properly rewire those cheap plastic connectors), I dont feel like learning the pinouts and stuff either plus I dont have a PS2 mouse. So i might as well get a serial killer... i mean mouse.
    Grin...
    However, if you ever run into a connector like that which you -have- to fix, there are tiny plastic covers over the metal plugs that hook into them. If you carefully lift such a cover up a little bit with for example a needle you can pull the wire + plug from the connector and reseat it in another slot. Thus no need to cut anything.
    Personally I don't like serial mice much, PS/2 mice have a more 'flowing' behaviour in my experience. .
    Jan 2015
    205
    Please disregard the text that was posted here before. I had multiple forums open on different tabs and I posted a post here, that was meant for posting on another forum online. I am thoroughly embarassed and would appreciate the topic not being brought up.
