April 22nd, 2017, 09:15 AM
#1
Nec versa 4080h
System Specs, drivers & manual for NEC Versa 4080H
Type of System: Laptops / Notebooks
Bus Architecture: 2x PC Card (PCMCIA)
Native OS: DOS / Windows
CPU Type: 120MHz Intel Pentium
Standard Memory: 8 MB (non-removable)
Maximum Memory: 40 MB
Memory Expansion: 1 socket
10.4" TFT Active Color Display
16bit Sound with Speaker / Mic Jacks
Infrared Port
Speaker & Microphone Jacks
Serial, Video, Parallel
Drivers and information that came on NEC VERSA 4080H hard drive.
NECINFO = NEC manual and introduction to NEC VERSA 4080H
NECUTILS = Battery voltage meter, program to help save shared files on HDD, Smart Switch driver, TEAC CD-ROM driver, PHDISK 2.7.
POWERPAN = Phoenix PowerPanel Power Management Configuration V 1.50.02
TEAC = CD-ROM driver for removable CD-ROM driver
TRANXIT = TranXit V1, Share files with infrared, parallel cable or serial cable.
USING95 = Interactive guide on Windows 95 by Modern Age Books.
VERSAGLD = NEC mouse drivers for Windows en DOS
Some drivers selected by Windows 98, I am guessing they are correct because everything works fine. Not sure if windows 95 has these drivers by default. Anyways the files down below have official NEC drivers:
PCMCIA controller = Cirrus Logic PCIC Compatible PCMCIA-controller by Microsoft 1999 Windows 98.
LCD screen = COMPAQ V50-colourmonitor by Microsoft 1999 windows 98
Screen adapter (aka video card) = Chips & Tech. Accelerator by Microsoft 1999 Windows 98.
Soundcard = ES688 AudioDrive by Microsoft 1999 Windows 98
DRIVERS & MANUAL: https://www.dropbox.com/s/8wrgae137h...4080H.zip?dl=1
Or: https://drive.google.com/open?id=0B1...kZ1TDlDZFptQ3M
- You may not post replies
- You may not edit your posts
Forum Rules
