Results 1 to 10 of 14
Thread: How can you get files onto a system that you don't have a disk drive for?
    Default How can you get files onto a system that you don't have a disk drive for?
    I ordered a compaq portable from eBay and it has a pair of 5.25" floppy drives and will come with a 2.11 dos diskette. I also ordered a 10 pack of DSDD diskettes to use with it. How can I get files to this system since I don't have any other 5.25" drives? All I will have is that 2.11 dos diskette, I would think it might have gwbasic on it. Is there any small program or can you use debug to make a small program that will transfer a file from the serial port to a file on disk? Any ideas?
    Feb 2011
    2,055
    10
    I have used a ".boo" encoded stripped down Kermit. The file is a simple ASCII encoded copy of the KERMIT.EXE file that can be copied down the serial port, along with a short basic program to decode it back to binary.
    http://www.columbia.edu/kermit/archive.html#boofile
    G4UGM
    30,694
    You can also hook a 3.5" drive (720K capable) to your Compaq in place of one of the 5.25" drives.
    If you have another machine with either a serial or parallel port you might be able to use LapLink or something similar.
    Mar 2009
    Pleasant Hill, CA USA
    2,705
    How would one do this? That is to say, how would one get the laplink software (or similar) onto the source computer?
    How would one do this? That is to say, how would one get the laplink software... onto the source computer?
    Laplink can be installed onto a remote computer via a serial cable connection.
    4,178
    Laplink might be a little large for a Compaq Portable. The install instructions for serial port transfer claim the process requires 300 kB of free space. http://kb.laplink.com/index.php/article/printer/716
    Not a lot room left to store files after that.
    Dec 2005
    Toronto ON Canada
    7,094
    Replace the disk; besides, there are two drives.
    After you successfully get Laplink installed on the Compaq just create a Laplink disk with only the EXE file on it. You don't need the all the install junk after you have a working disk.
    Furthermore, I wouldn't use Laplink V. I'd use Laplink II or III.
    6,141
    Any ideas?
    Some at http://minuszerodegrees.net/transfer/transfer.htm
