Results 1 to 2 of 2
Thread: Serial Cables for KVM
    Pittsburgh, PA
    1,240
    Default Serial Cables for KVM
    Setting up 8-Port KVM for my Retro Computers...
    3 of the 8 computers use Serial Mice. I know using a Serial to PS2 Converter coming out of the PC wont work as the mouse wont function from the console side. I am fine having two mice plugged in for the console (serial and a PS2) but for the connections from the PC to the KVM, can I use a straight through DB9 female to male cable to get the mouse connection through?
    Something like this - http://www.ebay.com/itm/5FT-1-5M-9-P...0AAOSw-YBXGWfq
    Or do I need something else? If this doesnt work, what is the purpose of each of the KVM ports having a serial mouse input as well as the console port also having one?
    "In Life, The Days Are Long But The Years Are Short..."
    Jan 2014
    Centero
    6,805
    Yes, that will work.
    Be polite and I may let you live.
