Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Sun SPARC Classic network problems
    Jan 2010
    Central VA
    3,902
    What are you plugging the Classic in to? As mentioned above, I've had issues with a fair bit of consumer gigabit hardware not wanting to talk to old 10baseT half duplex stuff. You might try a cross-over directly between the IPX and the Classic for diagnostic purposes. And, of course, if the TP port is truly dead, you can try the AUI port, or just add a SBus Ethernet board. I think I've still got a number of 10/100 and quad Ethernet boards for SBus, if you end up needing one.
    Jan 2014
    Northfield, MN USA
    119
    I'll second glitch on the issue of old gear on new switches. Both old Suns and old Macs can have problems talking to current auto-negotiate gear. I keep an old 24-port 10-BaseT hub in the rack just for this. The old machines plug into that, and that has an uplink to the higher speed switch.
    Cisco Catalysts tend to work OK when forced to 10/Half, but if you switch machines around on the switch (say, as things come on/off the bench) it's a pain to keep managing individual ports.
    Mar 2009
    Bainbridge Is., WA
    60
    In my experience, you never really know if a cable is bad unless you ring it out. And even then you don't know if it has isolation or crosstalk problems.
    If I suspect a cable, usually I make another one and see if the problem repeats.
    I don't suspect the cable since it works with my IPX and, now that I have checked, my other Classic. And, with reference to the two posts above, I don't suspect a problem talking to the hub/router. I can telnet into the IPX and the other Classic from a modern Mac.
    Mar 2009
    Bainbridge Is., WA
    60
    Quote Originally Posted by glitch View Post
    Is it more likely to be dead on the system board or the board that the TP connector is on? I'd like to take a shot at fixing it, if possible.
  5. #15
    Quote Originally Posted by tipo158 View Post
    You're probably right. But my point is that I can demonstrate borderline cables that work reliably in only nine out of ten machines. That's why to remove doubt I make a new cable. But if you don't have a spool of cable and box of connectors handy, that's not so simple.
    I found one just the other day that worked reliably at 100Mbs but intermittently at 1000Mbs. Because it was a very long cable, before making a new one it was easy enough to test it with two 10Mbs devices. It didn't work at all with those.
  6. #16
    Mar 2009
    Bainbridge Is., WA
    60
    I found my AUI dongle for the Classic/LX, tested using the network using that and it works.
  7. #17
    Jan 2010
    Central VA
    3,902
    Probably a blown out isolation transformer or something, then.
  8. #18
    Mar 2009
    Bainbridge Is., WA
    60
    I swapped out the System IO board (the "board that the TP connector is on") with one from another Classic/LX. (The part number for the board is the same for that board in the Classics and LXs (2 of each).) That did not correct the problem.
    Since I am prep'ing it to sell (I have 7 lunchbox systems at the moment), I wonder if I should pick up an ethernet sbus card for it or leave that as an exercise for a potential buyer.
  9. Default
    if you haven't sold it yet, yes, you should get an eth card for it. Note that all the sun4c/sun4m boxes have 32-bit Sbus. an AMD Lance card is the best you're going to be able to do with the bandwidth provided... you won't get more than 3-4Mbit/s on a 100Mbit Sun HappyMeal 10/100+SCSI adapter or a BigMac QFE adapter. these are made for a 64-bit Sbus and will work, but you won't get the full bandwidth a Sun Ultra 1 or 2 in the same manner would be able to give to it.
    I learned this the hard way with my SS5. doing some quick googling I found that the issue was the width of the Sbus itself bit-wise. faster Sbus speeds would help slightly, but the general rule is that you can't really make it perform any better than any 10Mbit card you can grab.
    That being said, there is at least one FDDI card that supposedly works in the SS5 on the 32-bit Sbus it has, at 32 bits, as that is what it was designed for... but I've not been able to find any sign nor picture of said card except for what is in a book. but, with a TP transciever shoved in, it might be able to get speeds over 10Mbits and thus be worthy of being a good shoe-in. The problem lies within that most if not all FDDI cards for Sbus are for other architechtures, 64-bit Sbus machines (i.e. Ultra 1/2) and do not work under anything but SunOS/Solaris.
  10. #20
    May 2017
    Finger Lakes, NY, USA
    20
    I bought this system and I'm successfully using it with a Sun AUI cable.
Tags for this Thread
