Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
Thread: Strange behaviour of a 5151 Monitor.
    Nov 2009
    Dublin, Ireland
    754
    Quote Originally Posted by paul View Post
    Did you change the colour/mono switch? http://minuszerodegrees.net/5150/mis...h_settings.htm
    Not sure if that would prevent a boot display though.
    PM sent on the other item.
    Doh! That could be the problem. I'll check later.
    I used the MDA card that was working on the first 5150 and the switches in the second 5150 set for MDA card. No luck.
    May 2006
    Melbourne, Australia
    5,565
    Quote Originally Posted by fjk61011 View Post
    With the motherboard switches of the second 5150 set for MDA, if you remove the MDA card then power on the 5150, you should hear a series of beeps (1 long, 2 short) from the speaker.
    That is the motherboard POST indicating that it cannot find an MDA card to initialise.
    Do you hear that ?
    Nov 2009
    Dublin, Ireland
    754
    Quote Originally Posted by modem7 View Post
    Do you hear that ?
    Tried that. beep 1 long 2short. Also tried MDA card with a NEC Multisynch which works.
    Think Stone might be onto something.
    May 2006
    5,565
    On the second 5150 ?
  5. #15
    Nov 2009
    Dublin, Ireland
    754
    Yes indeedy.
    Using paul's method to change the 5151 to 220VAC input for the second 5150's 220v pass through.
  6. #16
    May 2006
    5,565
    Do you know if your stepdown transformer connects though the ground connection ?
  7. #17
    Nov 2009
    Dublin, Ireland
    754
    Don't know.
  8. #18
    May 2006
    5,565
    Don't know.
    I was just curious, because the only scenario that I can come up with that might explain the symptom is:
    * Step-down transformer isolates ground; and
    * Loss of ground in the 5151's video cable (or where it connects to within the 5151).
    Seems unlikely, because in the 5151's video cable, two wires/pins carry the ground connection.
  9. #19
    Nov 2009
    Dublin, Ireland
    754
    I've started to convert the 5151 to 220Vac. Have removed the transformer, the voltage regulator and some class of a chip with three leg as per paul's instructions. Then my soldering Iron gave up the ghost before I could connect wires for the+ and - DC voltage.
  10. #20
    25,613
    20
    Wouldn't it have been easier to use a step-down transformer?
