Results 1 to 10 of 52
Thread: Tandy External Disk Drive help
    Default Tandy External Disk Drive help
    I have 3 Tandy external disk drives. I believe I could use these with my Tandy HX computer (one 3.5" and two 5.25"). I got these in a lot of other stuff and the cables were not included. They have a small plug next to the card edge where you would attach the cable. How did these hook up to the computer? Did they have an external power source or get power from the computer? Can I get the cables anywhere?
    Sep 2011
    896
    What are the catalog numbers of the three external drives?
    With the numbers I can help ascertain the suitability of these drives for MS-DOS application.
    Ian.
    Sep 2003
    Ohio/USA
    6,691
    The drives got power from the cable to the computer (for the HX external drives).
    I've noticed on some EX/HX Machines and External Drives a (I assume) ground wire has been added - any idea why these were deemed necessary on some units?
    My Retro Collection:
    Mac's: SE, LC630 & Beige G3
    FS: Brand New Tandy 1000 Adapters for EX, HX, SX, SL, TX & TL etc
    Doh, I didn't even think to check that catalog number. They are 25-1061 for the 3.5" drive and 25-1060B for the 5.25" drive. Can I still find the ribbon cables for these somewhere?
    Thanks!
    Quote Originally Posted by Gribnitz View Post
    Thanks!
    You can't even buy 30 pin edge connector with IDC termination anymore, I've been looking for weeks!
    I've managed to find some 30 pin edge connector's designed for through hole PCB mounting so I'm just going to solder them direct to the ribbon cable.
    If I'm successful making one for myself, I'd be happy to make you one if you like?
    Quote Originally Posted by dJOS View Post
    That would be fantastic! I love this Tandy HX, but most of my software is 5.25". I have found the 3.5" disks seem to go bad a lot faster than 5.25" as well. Please let me know if you get them to work!
    No worries, I have about 10 connectors coming so I can easily make more cables if they work. I'm hoping they are here by the end of the month and I'll report back in this topic.
    dJOS,
    Why can't you use a standard 34 Pin Edge Card Connector with a bit of the plastic milled off each end so it goes into the slot in the case.
    You could even insert two of the keying devices in the connector so it fits nicely on the 30 Pin connector. It shouldn't take long to mill
    a bit off each end to get things to fit properly.
    Another option would be to get some of the long tail headers from:
    http://www.king-cart.com/phoenixent/...KAWAY+.1SP+STR
    Part Number = HWS3835
    2x20 Header .1sp Long Tails .340 .230
    and push them into a standard Socket connector, then cut the long ends so they could be soldered to the existing
    circuit board on both sides. The Socket Connectors are also 34 Pin.
    Larry
    dJOS,
    Larry
    That's an option but imo it'd be ugly, at least with the connectors I've bought, I can shrink tube over the soldering so it'll look decent. I also don't want to Frankenstein my 1000ex either by soldering header pins onto the edge connector.
