Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Sdltrs
  1. Default
    Quote Originally Posted by Alphasite View Post
    I'd be interested in fixing the bug in the floppy controller emulation and giving it a try.
    Could you please share some details about this bug?
  2. #22
    Quote Originally Posted by Jenz View Post
    I checked and your copy has the fix that Tim Mann added to xtrs. Look for my name (Eric Dittman) in the source to find the details.
    I hadn't checked your source before as you took out the macOS support. If BartH's update was based on your source then it would be in there.
  3. Default
    Thanks for checking!
    "Only" the native GUI removed as it is dysfunctional on current versions of macOS. BartH ported my modified version of SDLTRS to the "Xcode" IDE.
    It is still possible to build without "Xcode" on the command line (SDL2 and autoconf from https://brew.sh) by just running the "configure"-script or executing "make sdl2".
