Results 1 to 8 of 8
Thread: Apple monitor to VGA adapter
    Default Apple monitor to VGA adapter
    Is there an adapter that would make an Apple Mac monitor work with a vintage PC with VGA? It's the only CRT monitor I have (I also have access to another Mac monitor)... finding CRT monitors locally seems impossible in my area and shipping is bleh...
    Quote Originally Posted by TravisHuckins View Post
    Here you go:
    http://www.ebay.com/itm/222523005433
    Thanks!
    Sep 2006
    Silicon Valley
    2,199
    Which Mac monitor?
    In the 80's, the monitors Apple supplied were fixed frequency and not VGA scan rates.
    Monitors that can do VGA had the product name Apple Multiple Scan Display
    https://en.wikipedia.org/wiki/Apple_...can_14_Display
    for example
    The adapters that are out there convert the 15 pin connector on Apple video cards to VGA, and these only work with later
    machines that have support and the select code for VGA in the video hardware.
    I'm not using the Mac with a VGA monitor... I want to use a Mac monitor with a PC.
    ... finding CRT monitors locally seems impossible in my area ...
    Using 'USA' as your area certainly doesn't help your situation one bit. Why don't you do yourself a favor?
    I live in the Cedar Rapids, Iowa area.
    It turns out I have a Apple Multiple Scan 15 Display. Works great with VGA! Thanks for linking the adapter!
Tags for this Thread
