Results 1 to 10 of 28
Thread: Did ever exist an 8-bit ISA card for ATA (IDE) hard drives?
    Default Did ever exist an 8-bit ISA card for ATA (IDE) hard drives?
    This morning I have seen in the local flea market a guy selling a 286 board with 2 ISA cards. One was an 8-bit ISA card made by Seagate. It was very similar to a MFM adapter card I have, but I noticed it had 2 40-pin connectors instead. So, I'm sure it's not for MFM drives.
    But, as XT-attachment (XTA) and AT-attachment (ATA) drives use the same physical connector... Could it be a rare ATA drive adapter for 8-bit ISA bus? (if it ever existed) or a more normal XTA drive adapter?
    The card had a chip with a silver sticker with Seagate copyright, probably a ROM. After leaving the flea market I wondered if an XTA adapter or an ATA one would need or not a ROM, but I reached no conclusion.
    If 8-bit ISA ATA drive adapters existed, the list must be very short. Does such list exist?
    Isn't that what an XTIDE does?
    4,797
    The ADP50 was an 8-bit ISA card to talk to 16-bit IDE drives, that's the only vintage board I've personally seen. Of course, the XT-IDE does exactly that nowadays, and is readily available, so while original cards are probably still pretty rare, they're no longer sought after at the levels they once were.
    Dec 2014
    The Netherlands
    2,024
    Quote Originally Posted by Rauli View Post
    Every HDD controller needs a ROM. This is because there is no 'standard' harddisk interface. Floppy controllers can be used without a ROM because IBM used a standard NEC765-compatible chip, and the code for this was in the standard PC BIOS. All clone BIOSes have also cloned these floppy routines, and all regular floppy controllers use the same NEC765-compatible hardware.
    Harddisks were not part of the original PC, so there was no standard, and no BIOS routines included for HDDs.
    Every HDD controller for a PC or XT would need its own BIOS routines to add BIOS-level access to the HDD, so that the main BIOS could boot from the HDD, and DOS could have sector-level access to the disk.
    Even for XTA you need a ROM. But I think the MFM interface was most popular in those days.
    ATs are a different story: With the AT, the ATA interface was standard, and it was included in the AT BIOS. So standard ATA controllers will not need a BIOS ROM in AT and clone machines.
    There were computers that had XTA on the motherboard; in that case, the XTA support could have been included in the BIOS ROM.
    Dec 2014
    The Netherlands
    2,024
    Quote Originally Posted by JohnElliott View Post
    Correct (in fact, the only two PCs I've ever had with an XTA interface have it on board), but in that case you wouldn't install an XTA card.
    Basically both the extension XTA card and its ROM routines are 'rolled into' the mainboard+ROM in this case. This is not XTA-specific of course. Any other kind of onboard HDD controller would be implemented in the same way.
    I would expect any XTA ISA-card to have a BIOS extension ROM chip on it, or at least require it to function (many early PC mainboards would have extra ROM sockets where you could install such). Either that, or you'd need to boot from a floppy and then load the BIOS routines as some kind of TSR before you can access the drive.
    I know XT-IDEs, I have a couple of them. With "ever exist" I meant in the XT times, sorry for not being clear!
    OK. So, being an 8-bit ISA card, it is normal to have a ROM, for XTA, and for ATA.
    As I don't have any XTA drive, I'm not intereseted in an XTA card, so now the question is: Is there a way to know which type it is (XTA or ATA) before buying and trying?
    No list of known 8-bit ATA adapters?
    No list of known 8-bit Seagate adapters? (that should be enough, as it is a Seagate card).
    The JUKO D16-X supports both XT and AT drives.
    Feb 2006
    Jacksonville, Florida
    1,296
    Very interesting, the 1st one, and dual XTA/ATA. Searching for pictures I found a thread about it here, in VCF: http://www.vcfed.org/forum/showthrea...is-it-any-good
    They even dumped the ROM so it doesn't seem very hard to clone... except for the PAL chip (sigh!)
    Quote Originally Posted by Chuckster_in_Jax View Post
    The 2nd one is very interesting, too. I found another thread in VCF about this card, but the photos are there: https://www.recycledgoods.com/acculo...1-16-isa-card/
    No ROM dump, and those 2 chips covered with sticker are probably custom (PAL or similar) chips.
    Maybe its for the photo quality, but this card looks like very recent in spite of being really old.
    I think the card I saw this morning is XTA, it could be http://www.uncreativelabs.de/th99/c/S-T/20192.htm (it's Seagate, and the connector and jumpers layout is exactly like I remember).
    But if somebody knows more ATA 8-bit cards, please, let me know in this thread.
