Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Did ever exist an 8-bit ISA card for ATA (IDE) hard drives?
  1. #21
    Jun 2006
    NC , USA
    1,107
    JDR Microdevices sold an 8-bit IDE card, this one has a limit of 528MB drives
  2. #22
    Dec 2014
    The Netherlands
    2,024
    Quote Originally Posted by mikey99 View Post
    Could that limit not be broken by Dynamic Drive Overlay (DDO) software such as EZBIOS, as you would do on later AT+ machines?
  3. #23
    33,661
    Recall that DDO's use their own low-level driver, not the BIOS one.
    I doubt that the I/O port mappings directly correspond to a standard ATA setup. There's usually some sort of adaptation employed to handle the 16-bit to 8-bit translation. In particular, note the 2Kx8 SRAM--that's not part of a usual ATA adapter.
  4. #24
    6,345
    Don't forget there were also many "hardcards" which marry the drive and controller onto the card. Does that qualify? Not sure if you can decouple them and wire up a different drive to the card, but there's an 8-bit IDE-ish HDD adapter for you.
    The only period-appropriate 8-bit IDE adapter I own is a Silicon Valley ADP50. The rest are XT-IDE variants of various flavors.
  5. #25
    33,661
    It depends. A lot of "hard cards" used 3.5" MFM/RLL drives with a bog-standard controller.
  6. #26
    And Tandy's "SmartDrive" hardcards used a Seagate ST-05X or an equivalent Western Digital IDE-XT interface card.
  7. #27
    Another period-appropriate card was the AccuLogic sIDE-1/16.
    The sIDE-1 was an IDE-XT (XTA, 8-bit IDE, whatever you want to call it...) card while the sIDE-1/16 was to use regular IDE-AT / ATA drives with an XT-class machine.
  8. #28
    Nov 2008
    Portsmouth RI
    374
    I've got several other cards from that company including a 4HD floppy card in 8bit isa. I tried for years to find their 8bit IDE card but could never find one except at insane pricing.
    Nice looking board...
    framer
