Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Need replacement or reworked D12887 CMOS battery
    I reseated the ram and the DS12887 and still no post... hard drive starts up but still nothing on screen and no beep.
    26,744
    20
    So what happens if you pull the 12887?
    Absolutely nothing... as in no change from with it in.
    And if anyone has the correct DS12887 that will work in this thing let me know. As I've mentioned above the new one didn't work right.
    Though I did notice that earlier when I was trying the replacement DS12887 that some of the pins had broken off and it wouldn't post. I could somehow have messed up the old dead one that used to at least post. If I try a good DS12887 maybe it will post again.
    I ordered a 128 byte DS12887 so I'll try that. Hopefully it will post again.
    And if not... if there's someone that could repair my system... I would love to speak with you.
  5. #15
    I would kill for a service/owner's manual for this thing... it might help.
  6. #16
    Quote Originally Posted by zombienerd View Post
    Be sure to use new Thermal paste on the CPU.
    The heat sink did not come off... I'm worried if the blow damaged the processor itself.
  7. #17
    26,744
    20
    Most any system will post part way with the Clock+SRAM chip removed. I suspect that you're battling something more significant. Have you tried the original chip?
  8. #18
    That's what I have been doing. That's why I'm afraid that I somehow broke my cpu...
    If I do have to replace the cpu do you think it would be a good idea to put a bit of a faster cpu in it? Like a 120mhz Pentium 1...
  9. #19
    26,744
    20
    You might have also broken a support chip or even a trace on the PCB. Obviously, the latter can be repaired; the former, not as simple.
Tags for this Thread
