Results 1 to 10 of 20
Thread: Getting old Mac software from the interenet without a modern Mac
    Default Getting old Mac software from the interenet without a modern Mac
    I currently have a mid 90's Mac that I would like to get some games on but every download gives me a stuffit file or a zip with files that my Windows 7 PC can't read. So, would this mean I would actually have to track down an old version of stuffit on an actual disk and then open the .sit files there? Or find some cheap modernish Mac to download the games off the internet with?
    using old macs in this new world sucks. you will kill many downloads by just downloading them on a pc and trying to copy them. I found an old G4 that ran OS( and used it on the internet to be a inbetweener.
    Recently my new fileserver has the ability to share files via AFS (apple file share). So I can just connect my mac to my internal network and copy the file that way. I even dedicated a whole hard drive to storage. I no longer kill any downloads, and I have an older G3 with networking, floppies and zip drives.
    It is a mistake to think you can solve any major problems just with potatoes.
    I just use a G3 macintosh laptop to copy files into it by a PCMCIA ->CF card and then copy files from it by a macintosh null modem cable. It works fine with all my older macs from IIci to 7600/120.
    Sep 2003
    Ohio/USA
    6,735
    First off if you use a PC don't save any file on a fat formatted drive because it will destroy the resource fork and be unusable on an old Mac (NTFS works fine). Some files should be installable with a double click, *.sit files will need a version of Stuffit (free and found online). I keep newer machines around for downloading and a Win2k server for file storage (last version to have built in Apple shares). Ethernet between machines works well, ZIP disks help.
    @unknown_k
    FYI, if you ever want to upgrade that server, Freenas has been wonderful. AFS worked perfectly in the limited tests ive done so far.
    Jan 2014
    Freedom City
    5,707
    The best "tweener" for a Mac is an Amiga. It can make 3" Mac disks of any size, and even run Mac software. If forks get lost, or otherwise out of sort, they can be easily righted from within AmigaOS.
    But to download files with one these days can be very expensive. So you pretty much need another machine to do the downloading anyway.
    I'll second the 'G3 as a tweener' notion. I'm actually using a G3-upgraded Powerbook 1400C for that purpose, with a Lucent/Orinoco WaveLAN PCMCIA card for network connectivity.
    2,597
    I've also used a Freenas server for exchanging files between Mac and PC. Works great, but that assumes the Mac has an Ethernet port and already has a functional OS installed.
    If you are not allergic to floppy disks, it is possible (although tricky) to write Macintosh 400k/800k floppy disk images using a Kryoflux. Even a brain-dead USB floppy drive will write 1.44mb Macintosh disks images but you would still need a tool to create the disk images with the files you want. And splitting large files is a headache. Programs like "Macdrive 95" enabled Win9x to recognize and read/write files directly to 1.44mb Mac formatted disks.
    Some people have previously mentioned using a SCSI Iomega Zip drive for the purpose of moving files back and forth.
    Using Basillisk II it is possible to connect a Mac SCSI hard drive to a PC SCSI controller and use it directly as a drive within the emulator. Not good for every day back-and-forth transfers but useful for getting a Mac installed, set up, or backed up.
    I agree that sites offering downloads in pure SIT format is rather useless these days. Sadly, much Mac software has only been preserved in that format. Redumps from floppy or CD are badly needed.
    I guess I won't have to worry about this because the only FAT32 drives my PC has are USB flash drives... and my old Mac doesn't have USB.
    Also my Mac has a CDrom drive that can read burnt CDs so that's how I would get software on it. I do have a few games on it (Lemmings and Sim City 2000) but that's only because I still have the floppy disks.
    San Antonio, TX
    209
    Well, a method I use (it's not pretty, but it works) is to use a Powerbook series laptop (the one I have is a 165c). I've been able to get Reader Rabbit and Wolfenstein 3D to work on it. All I do is convert any non-compressed/HQXed files to HQX format on my Macbook, and then split the files up into separate text chunks, use Mac-ette to create a Macintosh-compatible disk, transfer the text chunks, and reassemble them on the old Powerbook and convert them back into program data.
