Results 1 to 3 of 3
Thread: CBM PC10-III on-board video card problem - Plantronics ColorPlus compatible
    Default CBM PC10-III on-board video card problem - Plantronics ColorPlus compatible
    Hi Folks, I dug out my Commodore PC10-II and PC10-III CGA equipped machines after long long time. They both worked for a while when the smaller brother PC10-III suddenly died. Now it only beeps one long two short which indicates (IMHO) video card problem. What's even worse, I can not get VGA work in it now - before when on-board CGA was functional I could also use VGA. So it looks like I have nice doorstep
    It uses excellent Paradise PVC4 chip
    http://www.vcfed.org/forum/showthrea...ifact-Mode-Fun
    First question - what that error actually says, is the PVC4 chip dead or is there any hope that it is the CGA RAM only?
    Second question -would any diagnostic EPROM help in this particular computer? VGA, and/or on board CGA are not working ..
    If there is hope that it is only CGA RAM I am willing to try to unsolder them. I surely have two DRAM 4x64kB spares.
    Jul 2013
    Brisbane, Australia
    128
    Quote Originally Posted by archeocomp View Post
    A diagnostic EPROM like Supersoft/Landmark will still work in this case. If it can't initialise the video the diagnosis will be done by beeps from the PC speaker of which you will need to refer to the manual to understand what it means. Just run it without the VGA card as VGA is not supported by anyway.
    AtariPC.net
    Atari PC | IBM Compatible Series
    As described on the pages it sometimes behaves weirdl. I got following errors (with working keyboard attached):
    1 Hi/Lo - 4 short beeps - 8254 Timer 0
    2 Hi/Lo - 9 short beeps - NMI
    3 Hi/Lo - 2 short beeps - Keyboard scan lines
    BTW it is second time in a month or so, that I populated EPROM into socket reversed and in both cases the EPROM survived although I could see in both cases LIGHT in the chip's window.
