Page 8 of 9 FirstFirst ... 456789 LastLast
Results 71 to 80 of 85
Thread: XT-IDE rev 4 Development
  1. #71
    I managed to get the machine to run with Ms-Dos 5 but I have the same problem with Ms-Dos 3.3 ie if I try to make a primary or extended partition it tells me that it is not possible because a partition already exists, if I try to delete the partition tells me that there is no partition of the disk because ??
    I'm in big trouble maybe there's a problem with the setting?
    Please help me.
  2. #72
    Aug 2006
    Chicagoland, Illinois, USA
    4,961
    Try running "FDISK /MBR" and then run FDISK again. You must delete all partitions that already exist before you can create a new one.
    Offering a bounty for:
    - Documentation and original distribution disks for: Panasonic Sr. Partner, Zenith Z-160 series
    - Any very old/ugly IBM joystick (such as the Franklin JS-123)
  3. #73
    Jan 2010
    Central VA
    3,832
    And you may have a hard time if the partitions are non-DOS or created by a version of DOS newer than the one you're using. Might run WIPEDISK against the drive first.
  4. #74
    Perfect now everything works fine thank you !!
    First I limited my hard drive to 4096 with a jumper, now 13GB became 2GB.
    I was able to make the partition with FDISK and everything went ok, unfortunately I will not be able to install the original MS-DOS 3.30 floppies tell me if I'm not mistaken?
    Now I installed Ms-Dos 4.01 and it's all ok !!!
    I wanted to ask you one last thing ..., is it possible to disable the board menu with the choice of floppy or hard disk at startup?
    I would like it to load C: directly.
  5. #75
    Jan 2010
    Central VA
    3,832
    You can install MS-DOS 3.30 but you'll be limited to 32 MB partitions. Usually not a problem on the sort of machine you want to run DOS 3.30 on anyway You'll have to run WIPEDISK on it as MS-DOS 3.30 can't delete later DOS's partitions (it shows them as non-DOS and won't delete them).
    Yes, you can disable the configuration menu and just boot C: or have it do the typical try A: then C: -- you'll need to run the XT-IDE Universal BIOS configuration program and reprogram the board's EEPROM (it of course can do this in-board, so you don't need an EPROM programmer).
  6. #76
    Yes, you can disable the configuration menu and just boot C: or have it do the typical try A: then C: -- you'll need to run the XT-IDE Universal BIOS configuration program and reprogram the board's EEPROM (it of course can do this in-board, so you don't need an EPROM programmer).[/QUOTE]
    Thanks Glitch for the answer but I do not understand this passage ..., how do I get into the card's universal bios?
  7. #77
    Jan 2010
    Central VA
    3,832
    Use the configuration tool that comes with whichever version of the BIOS you're using. It's something you have to run from DOS, the configuration part is not part of the XT-IDE Universal BIOS that you see when the machine boots.
  8. #78
    Excuse me, I did not understand, maybe because I use the google translator !!
    Can the Glitch menu be removed from DOS?
  9. #79
    I'll ask you the last question and then I'll leave you alone!
    I inserted the HD LED cable from the XT-IDE card to the PC but I noticed that inserting it in one position the LED light stays on fixed, if you invert the poles the light as soon as you turn on the PC remains on weak and when it starts working the light works but in the opposite way, when the hard disk works, the light tends to go off while when the hard disk is no longer working, it remains lit but always weak.
    Do I have to change any switches on the XT-IDE card?
    Or does the PC LED work only if the LED on the XT-IDE card is not there?
  10. #80
    Quote Originally Posted by aesis View Post
    It's always best to ask if you're not sure, That's what these forums are for after all
    No and No
    Easiest thing to do is connect up another LED to the pins on the R4 card and see if it works as it should. I don't own any XT Clones but it might be the way the HD LED is wired on your machine, ie: On a circuit board ?. I've come across this issue before.
