Results 1 to 9 of 9
Thread: Looking for ideas on what is causing 5162 diags to freak out
    Aug 2006
    Chicagoland, Illinois, USA
    4,834
    Default Looking for ideas on what is causing 5162 diags to freak out
    I have an IBM 5162 that, aside from a failing ST-251 which I'm about to remove, works 100% perfectly. I've used it for many hours, tried lots of demanding software on it (timing-sensitive, custom hardware boards, etc.) and it runs everything perfectly...
    ...Except the actual 5170/5162 2.07 Diagnostics diskette. I've verified the disk, and a copy of it, read just fine on the 5162's floppy drive, but when I run it, I get strange combinations of characters that aren't printing out:
    (in the screenshot, you can see 4 lines are mangled) Because I can't get the diags to work, I doubt I'll be able to test some of the option hardware I have installed that the diags supports... I can't even change the hard drive type (with this program). Again, I stress that the system works perfectly otherwise, it's just the diags that fail in this very odd way.
    So, how does one diag the diag?
    Offering a bounty for:
    - Documentation and original distribution disks for: Panasonic Sr. Partner, Zenith Z-160 series
    - Any very old/ugly IBM joystick (such as the Franklin JS-123)
    Try another disk.
    I have v2.07 if you want it.
    I also have v1.00 and v2.03.
    ☞ Time flies like an arrow; fruit flies like a banana.
    Mar 2009
    Pleasant Hill, CA USA
    2,421
    I had similar issues when I tried to run the same diag on my 5162. I'll see if I get a chance this week to run try it again and post my results. Maybe send me a copy of the same one you are running and I'll see what it does on my unit as well.
    May 2006
    Hamilton, Ontario, Canada
    3,669
    And I have images of 1.02 and 2.02 if you need to devolve....
    It almost looks like the CGA test interferes with the characters writing to the screen. Could it be caused by the different RAM timing on the XT/286? Also would the old/new versions of the CGA card make any difference?
    Looking for: OMTI SMS Scientific Micro Systems 8610 or 8627 ESDI ISA drive controller, May also be branded Core HC, Please PM me if you want to part with one.
    Aug 2006
    4,834
    Try another disk. I have v2.07 if you want it.
    I tested with v2.07. I made sure that the mangled strings it was trying to print out were indeed intact in the program executable(s), and I made sure that the disk was fully readable by the computer before trying to boot from it.
    Quote Originally Posted by lutiana View Post
    I was using modem7's download: http://www.minuszerodegrees.net/soft...stics_2.07.zip
    Quote Originally Posted by mR_Slug View Post
    I had a VGA card in this system. Hm... that's something I hadn't thought of. Maybe the diagnostics don't deal well with VGA? I will try replacing the VGA card with CGA and see if it works any better.
    Sounds like you have those bases covered.
    Definitely a reasonable possibility. I wasn't aware that you were using VGA.
    Nov 2008
    Portsmouth RI
    321
    Is your bios stock or modified/upgraded?
  9. #9
    Aug 2006
    4,834
    BIOS is stock.
    Found the problem: The 8-bit Hercules VGA card was at fault. This card was known to have some compatibility issues at the time (see 1989 Inforworld archives) but the system came to me that way from an IBM employee so I never questioned it. I replaced with it a completely generic 16-bit VGA card (no idea what model is, it has a Western Digital chipset) and the problem completely went away:
    I'll drop a note to modem7.
