Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Ampro Little Board SCSI/PLUS HOST ADAPTER
    Apr 2009
    Morro Bay, CA
    478
    Success
    The problem with the drives is/was that when the eject button got pushed in without a floppy in the drive, it bent part of the linkage. I can't even figure out how it was possible.
    I'm experimenting with trying to get just the right angle on it.
    Now, on to see if I can get the hard drive working.
    Quote Originally Posted by phogren View Post
    Success
    Can you take a picture of the drive and highlight the linkage that got bent? I don't see anything that looks bent on mine.
    Apr 2009
    Morro Bay, CA
    478
    I'm not sure if I have the correct solution but I do know the problem:
    If you put a spacer under that long arm., i used a doubled up piece of cardboard, it pushes the spindle down far enough and the disk will spin.
    I am not sure which part is bent or broken but I am trying to figure that out now.
