Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: Norcom Model 3 clone
    Default Norcom Model 3 clone
    I pulled out my Norcom Model 3 clone today. I've had it for several years and other than a quick test when I first got it never did anything with it. I thought I'd check it out tonight. It's very dirty and the keys stick and when I did the quick test years ago one of the columns of keys didn't respond.
    The screen was stable during the quick test but now it rolls. Also the display blanks out. It's going to take quite a bit of work to restore it. I'll most likely put it aside for a while.
    In the meantime I've dumped the three ROMs (two 2764s with BASIC and one 2716 character generator ROM). Looking through the BASIC ROMs it looks like it's just the Model III ROMs but I haven't verified.
    I took three pictures of the system board.
    Sep 2011
    886
    Always liked the idea of a Model III in a Model I case. I remember the ads in 80micro... they only ran for a short time then vanished.
    I wonder how many they produced? Probably less than 1000...
    Ian.
    Interesting. So this was marketed as a drop in Model III replacement board for your Model I?
    This leads to an interesting question. What is needed other than a ROM replacement to make a Model I fully Model III compatible?
    Port vs Memory mapping is one thing, the IO bus, and disk controller are a few others.
    Morisset, NSW Australia
    197
    Looking at the connectors on the board, am I correct in assuming that the two 36 pin connectors are Drive 0+1 and Drive 2+3? Or is one for all 4 drives and the other a parallel port? The 50 pin is obvious enough.
    Does that also mean you don't have any serial connection?
    PJH
    There is a pin header in middle of board for RS232. I assume one is the printer and the other is the floppy port.
    Sep 2011
    886
    What's annoying is that maybe these have come up on eBay from time to time but since they look the same as Model 1s we may missed them due to not seeing a photo of the rear of the computer.
    197
    I never noticed the adds in 80micro for this. So can someone give a bit more of an overview? Did you order the board and it was up to you to provide the rest (keyboard, modified M1 case, power, ...) or did they sell them as full units?
    PJH
    Sep 2011
    886
    I'm thinking late 84 - early 85 were the ads. I'll have a look when I get home. If memory serves you can install it yourself or send them your M1 keyboard unit to upgrade it for a small fee.
    One 34-pin connector is the floppy connector, the other 34-pin is the parallel port, and the 50-pin is the I/O bus.
    As Tibs pointed out, the connector in the middle is the RS232 board connector. I don't have that board.
