Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: 8-bit ISA VGA card.
  1. #21
    But that's not true. Manufacturers made cards to work in both 8-bit slots and 16-bit slots because there was still an 8-bit market they could make money from. It wasn't just VGA cards: Many memory boards, network cards, sound cards, hard drive controller cards, etc. were designed specifically to work in 8-bit slots in the mid- to late-1980s.
    So, they were used "back in the era", and as such only "look out-of-place in an XT" if you didn't use XTs in the latter half of the 1980s.
    Well, I've seen plenty of XT clones, and from back in the era I can't recall any with a 16-bit card.
    It was much later, when TTL monitors became rare, that people installed 16-bit VGAs in XTs.
    On the other hand, I've seen plenty of 286+ machines with 8-bit VGAs, NICs, sound cards, proprietary CD-ROM controllers. And of course I/O, but these were 8-bit until the very end of ISA.
    I've got a Pentium 133 machine which came with a SB 2.0, probably from 1994.
    8-bit cards were available longer than XTs, I can't believe it was common to install 16-bit cards in XTs when 16-bit stuff was more expensive.
  2. #22
    Thanks, i forgot to ask the price...
  3. #23
    Aug 2006
    Chicagoland, Illinois, USA
    4,690
    Quote Originally Posted by Xacalite View Post
    Keep in mind our experiences are different. My experience was in the USA; I'm guessing from your location that your experience was Poland.
    Offering a bounty for:
    - Documentation and original distribution disks for: Panasonic Sr. Partner, Zenith Z-160 series
    - Any very old/ugly IBM joystick (such as the Franklin JS-123)
  4. #24
    Of course, mostly Poland, also Germany and other European countries.
    PCs around here were obviously made cheaper than those in the USA.
    But still, in late 80s XTs were low-end, so I'm surprised that people installed expensive 16-bit gear in low-end boxes.
