Results 1 to 10 of 10
Thread: Zenith Data Systems ZWL-183-92 Power Issues
    Mar 2017
    Niagara Falls, Canada Eh?
    440
    Default Zenith Data Systems ZWL-183-92 Power Issues
    I have had this Zenith Data Systems ZWL-183-92 for a couple years now.
    When I first got it, it only booted from the hard drive, when the battery was in and charged, but then the battery blew up.
    Now it will start with the power adaptor, but It won't boot from the hard drive, only from floppy, and it also turns on the red low power light and beeps.
    With a BIOS date of 1986, this is tied with my Macintosh SE as my oldest system.
    I have read somewhere that zenith powers things through the battery, so that could explain why it worked fine with the battery in.
    Now that I have no battery, is there anyway to change the power route, or attach something to where the battery connects to get power through there?
    After booting from a floppy the HD works, right?
    If so, you can then transfer control to the HD with this:
    SET COMSPEC = C:\COMMAND.COM
    Then you can remove the floppy (boot) disk and the machine will run as if it had been booted from the HD, i.e., reloading the transient portion of COMMAND.COM from C:.
    Mar 2017
    440
    Never tested that before. I will test it soon.
    EDIT: It says "invalid drive specification", so no it doesn't work. I'd expect the lack of proper power to be the culprit.
    Quote Originally Posted by ScanDisk View Post
    I have the ZFL-181-93, and it works fine without a battery. Don't know if that information would help you in any way.
    Current Vintage Equipment:
    IBM Thinkpad 390, IBM Aptiva A12, IBM PS/2 Model 25-004. Compaq Contura 4/25C.
    Asus P5A-B Socket 7 Box, Tandy 1000RLX-HD "B" & 1200-2FD, VIC20, Zenith ZFL-181-93, Packard Bell 300SX.
    Looking for: 286 Laptop, 386 Laptop, C64. Packard Bell Legend 20CD.
    You've checked the CMOS setup and the HD is still correctly configured, right?
    Mar 2017
    440
    I'm not sure as I don't see anything like that in the BIOS, but when I run disk tests it's light comes on, and it always fails.
    New Zealand
    3,886
    4
    You can access the rom monitor ok with ctrl-alt-ins or pressing esc on startup?
    Type ? and press enter. This will give you a whole lot of options. Option B is Boot from disk [0,1,2,3].
    BW0:1 enter should boot from the first partion of the hard drive(or rigid disk as the manual refers to it as.
    Mar 2017
    440
    Quote Originally Posted by Caluser2000 View Post
    No,
    but I can get something with CTRL + ALT + ENTER
    A friend of mine has the same model and the exact same problem as you describe. I suspect a faulty Dallas RTC chip, but this has to be confirmed (he hasn't opened it yet). I'll keep you informed of any progress we make. If you find something, please share!
    Mar 2017
    440
    Quote Originally Posted by SParent View Post
    Thank you, yes please keep me posted, I will indeed let you know if I make any progress!
    My Packard Bell has never given me any problems which were it's fault, the Packard Haters can stuff it! :
