Results 1 to 7 of 7
Thread: Hyundai Super-286E : how to enter BIOS?
    Feb 2012
    Ioannina , Greece
    180
    Default Hyundai Super-286E : how to enter BIOS?
    Hiya!
    I repaired a friend's Hyundai Super-286E pc but upon boot it complains about drives mismatch and that I should enter SETUP. How on earth do you enter the BIOS settings on this on? I also need to configure a replacement HDD and it won't be possible otherwise... any ideas/help?
    Thanks in advance!
    Does it boot from a floppy?
    If it does you can run GSETUP or SETUPNU or something like that.
    Feb 2012
    Ioannina , Greece
    180
    I'll will test if it boots from floppy... no idea if gsetup will work , setupnu is for phoenix bios so I won't even bother (machine bios is award). Ideally I want to enter the real BIOS setup
    Quote Originally Posted by keropi View Post
    ... setupnu is for phoenix bios so I won't even bother (machine bios is award)...
    Not to my knowledge, it isn't. I just ran it on my tweener with an AMI BIOS and it worked fine.
    Have you tried, CTL-ALT-ESC at start-up
    Have you tried holding a key pressed at power-on? Sometimes it complains about "keyboard error" and tells you how to enter the BIOS
    Feb 2012
    Ioannina , Greece
    180
    Quote Originally Posted by Malc View Post
    Yes that's it! And it needs to be pressed alt+ctrl+esc else it does not work for me...
    Thanks everyone for your help, appreciated!
