Results 1 to 8 of 8
Thread: Drivers for After Market hard drive for Radio Shack hard drive
    Mar 2017
    Oshawa Ontario Canada
    17
    Default Drivers for After Market hard drive for Radio Shack hard drive
    Or should i say software to partition and format the hard drive.
    Hello all,
    I picked up an after market external hard drive for my Model 4 and 4P.
    It is made by " Software support inc in the early to mid 80's.
    I have tried the standard RS drivers plus HDDFORM5C/dct-HDDVR6C
    and HDFORM5C.
    The /dct programs freeze after inputting all the drive info.
    The Hard drive in mine is a Seagate ST506 5 Mb but the HD controller if likely different.
    I have checked with TRS-Ian and he thinks VCF is my best chance.
    Does anyone have any drivers that may work ?
    If so can you email them to me ?
    Thanks
    Woody
    Post a picture of the controller board? I wonder if the WD drivers from Breeze would work?
    Instapatch for Konan DJ210 Hard Drive (1986)(Software Support Inc)[DSK].zip.
    This could help narrow down if that looks like your drive, this disk is for NEWDOS only though. Its available on the archives out there.
    May 2013
    Williamstown Victoria Australia
    374
    @woody
    Some files for your MODEL 1 that you were after sometime ago.
    MODEL1 LDOS
    Hi Woody I think that these are the Modified (Fixed Files )
    that you were after for the Model 1 ??
    Drop them in the Root of the Sd Card and import them to the Hard drive.
    These were given to me from Gazza a VCF Member.
    RSFORM1.CMD
    3631 Bytes Created 13 October 2013
    Modified 13 October 2013
    RSHARD1.DCT
    2810 Bytes Created 13 October 2013
    Modified 1 November 2013
    Ray
    Attached Files Attached Files
    If it ain't Broke then PLEASE DONT fix it.
    Procrastinators Unite.
    I keep telling you I am Not Pedantic.
    Mar 2017
    17
    Default Controller pictures
    Here is the controller plus board underneath
    Woody. (Doug)
    Yeah I think Ray might have them, tho those are for Model 1. I wonder if it was just a port change. Might be easier to compare the original RSFORM1/HARD1 to the modified to find the changes.
    Mar 2017
    17
    Ray,
    Thank you for your help.
    I have 2 EI's one for each of my model 1's
    But both are not working right now.
    Do you think it would work with the HD
    Connected to my M4 in M3 mode installing the drivers
    Under Ldos 5.31 ?
    Thanks
    Doug. Ve3GVW
    May 2013
    374
    @woody
    Sorry i Don't know.
    The files are for Model 1 Only
    Give it a try ( Model 1 Only)
    Ray
