Results 1 to 4 of 4
Thread: On set expert in LA
    Default On set expert in LA
    A production in LA needs an on set expert for Thursday November 2 and Monday November 6 to help with some mid-1980s Tandy tech.
    Please let me know if you are in the area and interested. I'll put you in touch.
    Mar 2011
    Atlanta, GA, USA
    1,548
    More specifics might help if you are still looking. Tandy had three large computer product lines in the mid-80s: CoCo, TRS-80, and PC compatibles.
    "Good engineers keep thick authoritative books on their shelf. Not for their own reference, but to throw at people who ask stupid questions; hoping a small fragment of knowledge will osmotically transfer with each cranial impact." - Me
    The main machine is a Tandy 1000 XL
    There is also at least one CoCo and probably some other stuff, although I suspect everything but the 1000 is background stuff. The XL is running and my understanding is that it will be used by the actors in the show.
    Quote Originally Posted by Erik View Post
    No such thing as a Tandy 1000XL... unless you mean the 1000RLX? Or the 2500XL? (Which is much closer to a standard PC clone, aside from the onboard Tandy DAC audio.)
