Results 1 to 3 of 3
Thread: Seikosha SP-1000AP DIP Switch Settings?
    Default Seikosha SP-1000AP DIP Switch Settings?
    Does anyone know what the DIP switch settings for the Seikosha SP-1000AP are? I'm trying to go through and test all my Apple II stuff, but I'm having trouble with this printer because I don't have the manual for it and have no idea what the DIP switch settings control or where they need to be set for my setup. I thought it could possibly use the same settings as the ImageWriter (as it's supposed to be ImageWriter compatible and the switch groupings are the same), but I tried to set the switches according to that documentation and it didn't work. I can get the printer to go into a self-test mode by holding down the "Line Feed" button while powering it on, but I'd love to know if the serial port on the back is actually functional, too.
    Well, if anyone can get the settings to me in the mean time, I'd still appreciate it, but since I found somebody selling the owner's manual on eBay I went ahead and bought it:
    I hope I find it worthwhile using this printer, because I just went on a day long repair session that started with an attempt to clean what I thought were stuck pins and ended with completely disassembling the print head so that I could re-solder wires that had somehow broken off a couple of the solenoids. xD
