Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Wing Commander 1 on my 386
    Oct 2016
    Cincinnati, Ohio USA
    346
    Why did you inject the XT into a discussion of your 386 issue??? I fail to see any relevance whatsoever.
    Because memtest86+ didn't work on the 386 or the XT-turbo, but did on my Pentium 120.
    PCjr, DTK PC-XT Turbo, 386DX 33, 486 laptop, Pentium 120, Pentium III 500, various old laptops, Commodore Colt, all working. I also have a 286 that I need to see if I can repair.
    Oct 2016
    346
    The title of the thread was "Wing Commander 1 on my 386", so we recommended a 386 memory testing tool. Also, you ran it on every computer except the one you're having trouble with. What does it do when you run it on your 386
    Don't remove memory until you verify memory is the problem. As for SIMMs going "straight down", that's what SIPPs do, not SIMMs. Does your memory have little pins, or is it a regular edge like all memory? If it's pins, those are SIPPs, and you just pull them out. If they're SIMMs, then there should be little tabs on each side that let them out at an angle.
    I did run it on the 386, it reboots the computer.
    Too late on the ram, I managed to remove it. They are 30 pin SIMMs, but pull straight up. I have never seem this before. The contact areas looked clean, but I gently rubbed them with an eraser to be sure. Re-installed in different order. Memtest still didn't work. I decided to try re-installing. Wing Commander booted up, but locked up later. Hmmm. Don't have a CD-ROM installed yet, but do have a CF reader. Copied the files I had installed from CD onto my Pentium and now the game runs fine. So it was apparently just that the diskette version I bought has errors.
    Thanks for trying to help. Now I need to read the manual. I promptly died.
    Oct 2016
    346
    Got through the first mission once. Tried it again and ran into an asteroid on my approach to the Tigerclaw. Now I remember much I hated dodging rocks when I first played these games. It's still a fun game, but my 60+ year old reflexes make it difficult.
    Oct 2016
    346
    Made it through the first two missions. Found online that you can shoot the rocks. Going slow (150-200) and shooting any rock that is straight ahead helps a lot.
  5. #15
    Dec 2017
    Union County, NJ
    14
    Quote Originally Posted by KenEG View Post
    ...When loading WC, it gets to the message "expanded memory detected" then starts to display another message, but reboots before I can read it. Anyone have any tips for trouble shooting this?
    This is not directly related but generally when I encounter this sort of an issue I end up setting up my phone as a camera on a tripod so then I can go back frame by frame and at least have a better look at the error. Sounds cheesy but it works...
