Results 1 to 4 of 4
Thread: Microsolution backpack parallel cdrom with sound. DOS driver?
    Default Microsolution backpack parallel cdrom with sound. DOS driver?
    I got a hold of this external parallel cd-rom drive that has a built-in 16-bit sound card (some models had it others didn't). Unfortunately the makers only offered drivers for windows3.1 and/or windows 95. They were supposedly looking into adding drivers for DOS but as far as I know that didn't happened.
    I found this thread related to one of the earlier models: http://www.vcfed.org/forum/showthrea...M-Sound-Option ,mine being one of the last models.
    I took it apart and found that it has the "ES1688F" chip (Sound Blaster compatible) found in many good 16-bit sound cards (see pics below)
    https://pp.userapi.com/c840535/v8405...Uh0BVgf_Yw.jpg
    https://pp.userapi.com/c840535/v8405...ZOI24sWfWk.jpg
    https://vk.com/id456443069?z=photo45...all456443069_2
    My question is, what are the chances that there is a driver that would let me access MS-DOS sound to this built-in card through parallel port? (yes I know is wishful thinking).
    Here's a later model without the sound option
    Any reason you can't use a real sound card? Using it with a laptop?
    Quote Originally Posted by TravisHuckins View Post
    Correct. Maybe it may come handy for something like my IBM model 50 too.
    Aug 2006
    Chicagoland, Illinois, USA
    4,561
    Parallel-port sound devices require a 386, a driver or TSR, and a memory manager loaded (like EMM386 or QEMM), so that the system can be put into V8086 mode, so that port writes to sound blaster ports can be intercepted and redirected to the sound device on the parallel port. Without those three things, you won't get sound.
    Offering a bounty for:
    - Documentation and original distribution disks for: Panasonic Sr. Partner, Corona PPC-400, Zenith Z-160 series
    - Any very old/ugly IBM joystick (such as the Franklin JS-123)
