Results 1 to 3 of 3
Thread: Need MFM/RLL/ESDI 20-pin data connector without locating key
    Mar 2004
    588
    Default Need MFM/RLL/ESDI 20-pin data connector without locating key
    Not actually DEC but hopefully someone on the forum can help. I'm looking for a 20-pin edge connector similar to that used for the data cable on MFM/RLL drives but without the locating key in the connector (or with a removable key).
    The application is for a test connector on the CPU card used in HP 98x0 desktop calculators. The card has contacts in the same configuration as an MFM drive but without the slot, so a keyed connector won't fit. The only cables I had on hand have the key actually molded in and so far I've destroyed two cables trying to cut out the key without damaging the adjacent contacts.
    Any help appreciated - parts, cables, part numbers, etc.
    Thanks,
    Jack
    I have some without keys.
    What length are you looking for?
    Mar 2004
    588
    Length doesn't really matter since I'm just going to terminate it on a piece of perf-board with pins for my logic analyzer. I'll PM you with address etc.
    Thanks!
