Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Floppy Controller with BIOS need.
    Mar 2009
    Pleasant Hill, CA USA
    2,508
    Quote Originally Posted by Plasma View Post
    It just needs to be aligned on a 2K boundary so the system BIOS can find the signature.
    How is this done, with the EEPROM burning software? Or some sort of voodoo with the copy /b+ command?
    Well I don't know what EEPROM software you use. I build all my images with a hex editor. But since the floppy BIOS is exactly 8192 bytes, you can just append the IDE BIOS directly with copy /b.
    Mar 2009
    2,508
    Huh? Your ESP on the fritz again? The programmer I have uses the minipro v6.6 software, which may or may not be meaningless to you...
    Check your PM box ASAP.
    Join the penny pincher army today!
    Jul 2010
    Silicon Forest, Oregon, USA
    668
    Mar 2009
    2,508
    Quote Originally Posted by sergey View Post
    Yes. I had found your site, and it looks pretty good. But I am not sure how I'd go about getting a few kits to assemble though. Or how to work out which bits to populate and which not to (I am a complete novice to that level of circuitry).
    What I do know for sure is that whichever way I go with this I am using your BIOS
