Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Installing Windows 95
  1. #21
    You could try SUBST.
    ☞ Time flies like an arrow; fruit flies like a banana.
  2. #22
    Jan 2013
    Marietta, GA
    Sorry, Stone. It is smarter than that.
    The floppy version always wants to write back to disk1 to record user/company info. However, it gets confused if you run it from the hard drive. Off hand I only know of two ways to fix that.
    1: Either start over and copy the CAB files from a CD-ROM version.
    2: Create a text file in your setup folder named "MSBATCH.INF" and add the lines:
    And then run setup again.
  3. #23
    Sep 2008
    Walled Lake, MI
    The Toshiba 1910 supports PCMCIA so why not just find a cheap, working, PCMCIA CD-ROM on Ebay and take the easy way out. I personally have an EXP Memory Products 4X PCMCIA CD-ROM which is virtually NIB. It was manufactured in 1996 and can run on 8 AA batteries or the 12 vdc power pack. If you intend to keep the 1910 around and play with it, might be worth the investment. Just a thought.
    Late edit: After nosing around in the packaging, I discovered a 1.44 floppy that contains the Windows 3.1 & 95 CD-ROM drivers, along with another floppy that has the PCMCIA III drivers.
  4. #24
    Someguy, I think you've done it!!!!!
