Results 1 to 9 of 9
Thread: ISO Commodore cables
    Feb 2011
    Eugene, OR
    1,647
    5
    Default ISO Commodore cables
    I own a working Commodore 64, with Dataset, and 1541 Floppy, but there are no cables to connect the floppy , and itís power supplies. Unfortunately, I havenít been too tell what I need. From what I can tell, I need a separate power for the floppy, plus I need the cable to connect the floppy to the computer.
    So, can someone tell me what I need to connect the computer, and floppy drive, and ultimately to a TV, or monitor?
    And as always, Thanks much.
    BB
    Wanted: - Complete SERIES ONE TRS-80, IBM 5170 AT, Original authentic IBM 5100 Portable, IBM 5151 Monitor. Also looking for Packard Bell 75Mhz computer, Commodore Pet w. Built-in cassette drive, amber 12Ē CRT, Mac SE-30 hard disk to replace the bad drive currently installed, TRS-80 Coco series 1 upgrades including memory, IBM PC 5160 compatible CD ROM.
    Apr 2009
    Morro Bay, CA
    513
    You must have a 1541-II which does require an external power supply. The 1541 just requires a standard power cable and has an internal PS.
    You need a serial cable from the drive to the computer
    You should get a 5 or 8 pin audio video cable
    All of them are widely available on Ebay and amazon
    Jan 2014
    Freedom City
    5,723
    Do you have a power supply for the C64? If not, do *not* buy an original one. It will cook the C64, sooner or later. There are newer designs.
    @KC9UDX - I've just "unearthed" my cache of old Commodores... Is there a way to test the power supplies? What exactly happens, is failure inevitable? I've got a box of C= power bricks in the basement, but don't want to cook anything...
    Jan 2014
    Freedom City
    5,723
    Quote Originally Posted by LesB3 View Post
    Unfortunately, you really only know when it's too late. I don't know that failure is inevitable, but it is very likely. Too likely to risk burning up a C64 beyond justifiable repair.
    What happens is that the 5V regulation fails. This 5V supply tends to end up at around 9V. None of the expensive custom chips in the C64 will tolerate this.
    I thought there were inline protection devices that you could buy. If so, possibly someone here knows where you can get one. I think that's a good solution for someone who has a number of these supplies. If no one is selling then complete, you can always build a simple crowbar overvoltage protection device.
    Quick question... Does the "inevitable" apply to the disk drives with external PS's? I.E. 1541-II, 1571, 1581...?
    Jan 2014
    Freedom City
    5,723
    My 1571 has an internal supply.?
    But, in any case I don't think so. The C128 supply, The upgrade C64 supply (that comes with the REU) and the Amiga supplies don't have this problem, so my guess is that the later disk drives don't either.
    Sorry! forgot the "-II" on the 1571...
    Thanks for the info!
    Nov 2003
    Landenberg, PA USA
    3,774
    Hey I just noticed that you live in Aston, PA....I live in Landenberg (down rte 1 in PA)....The issue with the power supplies is simply aging. THere were and are now after-market power supplies that are safer to use. It's best to buy a new power supply and leave the original in the box. THat said I have many that work just fine. You just have to be careful.
    b
    @ BillDeg:
    Web: vintagecomputer.net
    Twitter: @billdeg
    Youtube: @billdeg
    Unauthorized Bio
