Thread: Gemini GM925 80bus serial keyboard anyone ?
    Nov 2017
    UK, South East
    127
    Default Gemini GM925 80bus serial keyboard anyone ?
    Folks,
    I have just acquired this Gemini Z80 based 80bus computer - model GM925.
    Problem is that it dod not come with a keyboard and seems to use a proprietary serial keyboard with a 6 pin DIN connector.
    Extract from the system manual for the interface board shown in the attached image.
    Can anyone recommend a potentially compatible keyboard or am I going to have to build an interface ?
    Thanks
    Nov 2017
    UK, South East
    127
    Well I have finally managed to find the correct keyboard for this system.
    Where did you end up finding it? Congrats. I ran into the same problem last year with an ITT system. The keyboard was harder to find than the system itself. By total luck a hardware collector I know had one in his pile.
    Nov 2017
    UK, South East
    127
    Quote Originally Posted by liqmat View Post
    I bought it along with a whole bunch of Gemini 80Bus processor cards from a chap on Ebay - a lucky find.
    I have an emulator for this machine - see http://81.105.120.101/xbeaver/
