Page 5 of 5 FirstFirst 12345
Results 41 to 42 of 42
Thread: Aluminum, Zinc, Brass casting?
  1. #41
    Apr 2011
    Brisbane, Australia
    401
    9
    Yeah, agree that fitting nuts onto bolts in engine bays can be a problem. I've not run one off yet to try but next time you have access to a 3D printer, this "finger nut wrench" looks useful: https://www.thingiverse.com/thing:947423 I'm thinking a workalike could be fashioned from an offcut of PVC conduit or the neck of a PET bottle.
  2. #42
    29,635
    20
    The job wasn't done with much in the way of tools at all--although your biggest flat-blade screwdriver does help in getting the rear caps off. Example here. I usually send my better half away when doing a job like this--I can be as nasty as I want then.
    Inevitably, one of the push-in fasteners flew off somewhere into the body, but I've got plenty of spares.
    As the video illustrates, there's a good reason for using genuine Philips lamps--the market has been swamped with Chinese counterfeit junk to the extent that Philips now puts a hologram and security codes on the packaging that you verify on their web site.
