Results 1 to 10 of 14
Thread: increasing pc speaker volume?
    Default increasing pc speaker volume?
    My DOS PC's speaker is kinda quiet. How would I go about increasing it's volume for games that only use that for sound? Would I have to replace the speaker itself?
    27,362
    Depends on how far you're willing to go. You can install a cheap amplifier that takes its input using a dummy load resistor and a coupling capacitor in place of the original speaker--and use the original speaker fed by the amplifier. Shouldn't take more than a watt or two of amplifier. There are probably kits on eBay.
    Dec 2014
    The Netherlands
    2,024
    Some sound cards have a PC speaker connection on their mixer, such as the Sound Blaster Pro. You can just connect a wire from the PC speaker header on the motherboard to the sound card, and then the audio will be routed via the mixer and the onboard amplifier of the soundcard, allowing you to use headphones or speakers.
    For unpowered speakers connected to a SoundBlaster card, make sure to install the SoundBlaster software. You can then set the volume there (and make sure to adjust the volume knob, too.) I learned that recently. :P
    What component of the sound are you missing. A 2.5 inch speaker will never produce window shattering base unless the cone flies out and hits the window.
    It's just too quiet overall... games with adlib music but pc speaker sfx the sfx gets drowned out by the music at low volumes even.
    Jan 2014
    Freedom City
    5,558
    "Back in the day" the easiest solution was just to connect a 12" speaker instead of the standard one.
    27,362
    ...or just use a set of headphones. Plenty loud and won't annoy the quiet souls around you.
    Jan 2014
    Freedom City
    5,558
    But make sure to install a potentiometer. That POST beep can be deafening.
    My PC setup is in a giant room where I also have a bunch of musical instruments and a recording setup so I'm not worried about annoying people. lol
