Results 11 to 20 of 22
Thread: increasing pc speaker volume?
    31,824
    18
    Do you have a separate amplifier with line-in inputs? You can use that...
    I might try the Sound Blaster approach or try using the speaker from my old Gateway 2000 which was much louder if I could get it out.
    I installed the speaker from my Gateway 2000 case and it puts out a good volume. I can actually hear them in games with adlib music now! The strange thing was that the speaker had the same specs but just louder for some reason. I guess early 90's speakers had better volume than the ones in the later 90's.
    31,824
    18
    Actually, for the best match, you should be using a high-impedance (say 16 or 32 ohms) speaker. Or better yet, try a small output transformer, say 500 ohm to 8 ohm. That's my reckoning anyway...
  5. #15
    Mar 2011
    Atlanta, GA, USA
    1,449
    Related question: I'm working on a project where I need to capture PC speaker audio accurately on an external board. I've considered a couple solutions and am about to build a board to test all of them. And then this thread started me questioning by current method. I want to capture the true acoustic sound coming out a typical 4 or 8 ohm speaker ala 5150. It doesn't have to be real time.
    The external capture card has other analog circuitry on it and needs to have a clean analog domain as possible. So rather than connecting the (-) speaker lead to the card's local ground, I figured I treat the input as a current loop. I have the speaker inputs run through a 16 ohm resistor and input side of an opto-isolator. The other side is a Schmidt open-collector output to a digital pull-up to the input of my capture IC. I figured with only a PIT driving the speaker, this would transfer the pulse modulated wave-form accurately to my capture device. Then I could apply a set of filters in post that mimic the frequency response of any physical speaker I want.
    Does this sound sane? Or should I try and use an ADC instead?
    "Good engineers keep thick authoritative books on their shelf. Not for their own reference, but to throw at people who ask stupid questions; hoping a small fragment of knowledge will osmotically transfer with each cranial impact." - Me
  6. #16
    Aug 2006
    Chicagoland, Illinois, USA
    5,947
    I've already done some tests on this very subject. It's not finished, but I have samples and reasoning for you to watch. I'll send you an email.
    Not only a PIT drives the speaker -- there were CPU-driven methods. Not sure if your circuit accounts for this, or whether it is even relevant for your purposes.
    Offering a bounty for:
  7. #17
    Sep 2008
    SE MI
    4,050
    6
    Depending on you particular system and sound card, some BLASTERS have an input jack for system sounds as well as an input for CD-ROM's.
    Surely not everyone was Kung-fu fighting
  8. #18
    Aug 2006
    5,947
    Sound cards that route speaker audio have their own set of pros and cons.
    It's killing me that I don't have my video on this very subject finished. I'll try to finish it up this weekend and post a link here.
  9. #19
    31,824
    18
    What Jim said--it's quite possible to do software-driven PWM through the speaker, for example.
  10. #20
    Mar 2011
    Atlanta, GA, USA
    1,449
    This is good because I'm about to wrap Jim up into this project. So careful about getting me excited!
Tags for this Thread
