Results 1 to 3 of 3
Thread: Intecolor 8300.... ?????
    Default Intecolor 8300.... ?????
    What is this????? Never seen or heard of anything like it and info on Google is scarce at best.
    Looks interesting....
    https://www.shopgoodwill.com/Item/46143954
    3,955
    You may have more luck looking for the related terminals under the name ISC (Intelligent Systems Corporation). The very similar computer design was marketed as Compucolor.
    http://pc8800.com/pc8800.html is for an emulator of the Intecolor terminal and might help with some ideas on what it can do.
    Dec 2005
    Toronto ON Canada
    6,993
    AFAIK it's a terminal, not an actual computer. I've got some Intecolor manuals but not that one, but here's one on Bitsavers:
    http://bitsavers.org/pdf/intelligent...nual_Nov86.pdf
    BTW, I think it might be a 3800, not 8300.
    m
