Thread: Atari 520 STFM Vertical line on the display
    Default Atari 520 STFM Vertical line on the display
    Hi Folks,
    I have vertical lines on the display of my STFM. The are black when on the desktop but change to other colours depending on the background oimage.
    So far I have ruled out the display (monitor) and the PSU, by substitution.
    Do anyone have any ideas what could be the cause.
    I would be most grateful for any help you could offer.
    Tel
    Dec 2008
    libtard capital, California
    1,001
    looks like memory gone bad.
    If programs/games/demos still run correctly then it could be a bad connection of the shifter chip.
    From memory: In the early days they were socketed, later Atari added a clip to keep the chips 'in' and after that they simply soldered them directly to the board.
    Feb 2011
    1,801
    10
    Quote Originally Posted by gertk View Post
    Please don't try the old "drop from 2 inches fix" which was commonly advised in the past. Take it apart and re-seat the socketed chips
    G4UGM
    Thanks Guys,
    Alas all my chips are soldered except the roms. I have studied the shifter from above and it looks like it may have a dry joint on pin 40, I will take the board out and re-solder when I get a chance.
    Does anyone know what pin 40 does. I am assuming it is pin 40. Its the one opposite pin 1 so I guess it could be pin 2, not sure.
