Results 1 to 6 of 6
Thread: Seeking HD replacement for Mac SE30
    Feb 2011
    Eugene, OR
    1,647
    5
    Default Seeking HD replacement for Mac SE30
    Along with the 15 or 16 computers in my vintage computer colllection, I own a Mac SE30 with a failed internal hard disc drive. Sadly, I havenít been able to locate a replacement that is known to function properly.
    Does anyone here have a working replacement that has been tested? As always, please send me PM, with your price and shipping options to postal code 97477.
    Thanks much..
    Thomas
    Wanted: - Complete SERIES ONE TRS-80, IBM 5170 AT, Original authentic IBM 5100 Portable, IBM 5151 Monitor. Also looking for Packard Bell 75Mhz computer, Commodore Pet w. Built-in cassette drive, amber 12Ē CRT, Mac SE-30 hard disk to replace the bad drive currently installed, TRS-80 Coco series 1 upgrades including memory, IBM PC 5160 compatible CD ROM.
    1,094
    Any 50 pin SCSI drive should work, you just won't be able to have partitions larger than 2 GB.
    May 2017
    Finger Lakes, NY, USA
    23
    Quote Originally Posted by mdanh2002 View Post
    SCSI2SD is also available at http://store.inertialcomputing.com/category-s/100.htm or https://www.itead.cc/scsi2sd.html and the project page for it with documentation, downloads, etc is at http://www.codesrc.com/mediawiki/ind...?title=SCSI2SD .
    San Antonio, TX
    209
    My suggestion, if you have experience, try replacing the capacitors on the electronics board.
    Another vote for SCSI2SD!! I am using an 76GB 10k RPM HDD in mine, but once it dies I will be going SCSI2SD, slowly replacing all my spinning drives as they die.
    You can do larger partitions in OS 7.5.3+, however LOTS of space gets wasted with the huge block size, the larger the partition the more space gets wasted, I tend to keep the partitions about 4-8gb, decent compromise, not too many partitions, but not too large of a block size.
    My Vintage computer/blog site
