Results 1 to 10 of 18
Thread: Help setting up mTcp
    Jun 2014
    Salt Lake City, Utah
    453
    Default Help setting up mTcp
    Hi,
    I have an 486 system that I am trying to set up mTcp on. Iím using a NE2000 compatible ether net card. I am using the Crynwr packet driver (v 11.4.3) running from my autoexec.bat. I call it by NE2000 0x60
    When it loads it shows that the software interrupt is 0x60, Interrupt number 0x9, and the I/O port is 0x300. It then gives me my MAC address.
    In my mtcp.cfg file I have the packetint set to 0x60, I also have my ip address information hard coded. In the mTcp log file it shows all of the correct IP configuration information. ip,netmask,gw, and nameserver.
    When I ping an a machine in my network I get ďTimeout waiting for ARP response.Ē From the mTcp ping client. I know itís a good address as I can ping the same address from any machine in my network.
    Using tcpdump on another machine both running on the same Ethernet hub (NOT A SWITCH) I can see the ARP requests going out and the queried machine answers the ARP request . For some reason the mTcp stack does not appear to be receiving the ARP reply.
    I know the Ethernet cable is good. I tested it physically with a cable tester. I can also see the traffic LED on the Ethernet card flashing. And outbound traffic reaches my sniffer.
    Iíve also tried a different Ethernet card.
    Any tips would be really appreciated. Might I have an issue with the HW int 0x9?
    Cheers,
    len
    New Zealand
    3,846
    4
    Run the dhcp program. It'll set the network values in tcp.cfg. This sorted a problem I was having.
    Is the SET MTCPCFG = C:\mtcp\tcp.cfg set in the autoexec.bat file?
    If you are able to send packets but it looks like you can not receive packets then it is almost always a problem with the selected hardware IRQ. If the hardware IRQ for the packet driver is not set correctly then incoming packets never make it to the packet driver, and then never make it to mTCP.
    Please double check our hardware interrupt number and look for conflicts. On a 486 system IRQ 9 should be safe to use.
    Jun 2014
    453
    That's what I was thinking, it's just been decades since I was "expert" with these systems. I thought it would be easier to get this going on a newer machine before I set it up on my 5150 or 5155... I still need to fine a suitable 8 bit ethernet card.
    In any case, being dumber that I was in the 80's, how can I tell what HW interrupts are currently used by the system. I pretty much have standard HW in the system. (IDE, two serial, VGA) With a NE2000 can I force it to use a different INT?
    What 8 bit ethernet cards are you guys using in your PC/XT systems? 305's?
    len
    Jun 2014
    453
    GOT IT!!!
    Thanks to you Linus for the miracle of Linux. I pulled the ethernet card in my bench Linux system to detect the current configuration of the card. It told me that the card was set up on INT 10. With the addition of an 0xA on my dos driver init I am now cooking with gas! So much to remember.
    Now I'm off to find cards for the older PC's.!
    Thanks for your responses guys. It helps to kick start and old brain.
    len
    3,884
    Yeah, a lot of the crynwr drivers will initialize with the wrong IRQ, and you get exactly what you've described. FWIW, Linux kernel modules will too, sometimes, especially if you let them autoprobe.
    New Zealand
    3,846
    4
    Nice to see another mTCP user. Well done.
    Jun 2014
    453
    Quote Originally Posted by Caluser2000 View Post
    It's heartwarming to have a community to help out.
    As to your Thomas Byers quote... Although not the A> prompt, it you count the zillions of Linux prompts he may have way underestimated those who spend their lives at a command prompt. (As I do.)
    A few weeks ago I built an 1802 membership card. I've designed a nice little interface around a Raspberry Pi 3 that interfaces to the M.C. When I was writing the software, which is ncurses based, I remembered how fast the non mouse/icon driven interfaces were. The functionality is not M$ word by any means, but for a simple tool it just works. I have always tried to tell others how inefficient it is to take your hands off the keyboard to grab the mouse, few understand.
    Long live the "A>"
    len
    Jun 2014
    453
    YEA!!! Got my 5155 connected to the Internet with mTCP! Thank you to Glitch for all the help, not to mention a second XT-IDE.
    I got a matching 5.25 IBM drive off ebay to replace the screwy drive someone previously had crammed in the lower slot. I also completely dissembled the keyboard to fix the non-working ':' key, was a real problem trying to change drives, although the "alt" keypad got me though for a few tests.
    Very very cool little computer.
    Now back to do networking on the 5150.
    Cheers all!
    len
    Jun 2014
    453
    Another success tonight! I got the 5150 connected to the Internet with mTcp.
    I used htget to download Tetris and played a game.
    Just feels like magic.
    len
