Results 1 to 10 of 53
Thread: "removable disc/cartridge" SCSI drives that can act as a fixed disk drive
    Default "removable disc/cartridge" SCSI drives that can act as a fixed disk drive
    Do these exist? My two lovely internal Zip100 drives won't boot as a hard drive on my ST01 because they report the RMB bit, therefore it gets confused, sees the drive, but does not recognize it or report it's ID/LUN because it's removable...
    Join the penny pincher army today!
    Mar 2009
    Pleasant Hill, CA USA
    2,504
    Jaz drives do this. In fact IIRC you have to run software to be able to hot swap cartridges.
    Jan 2014
    Freedom City
    5,700
    I'd get a different controller. I've been using those discs that way for as long as they've been round. But I doubt I've even seen an ST01.
    I know these work well with Macs: https://en.wikipedia.org/wiki/SyQuest_EZ_135_Drive
    It is a mistake to think you can solve any major problems just with potatoes.
    Years ago I got a zip drive dirt cheap as they hit the shelves. Nice to have friends. Anyway I used it with my Mac II, probably hadn't upgraded it to a IIx at that point. It never was bootable, as the scsi address was fixed iirc. It would only occupy 6 or 7 on the acsi chain and was switch selectable iinm. Neither would it boot on a DEC 486 pizza box I obtained later, for the same reason. That thing was dreamy, it sync'ed right up to a 64khz fixed frequency monitor. I dropped a floppy disk on the open motherboard and it was always flakey after that. Can't say if a different scsi card would've made a difference, nothing back then afaik. I was using the proprietary Iomega controller with the DEC.
    The internal drives support an ID of 0; so it shouldn't be much of a problem here. PLUS I do have another SCSI controller, the TMC-845, but I fear that the TMC-950 v8.2 BIOS won't even support the Zip drive as well; I tried booting it with the int 19h-based XUB floppy bootloader that someone posted here a while ago; BIOS couldn't find any drives, but SCSIDIAG works like a champ!
    A shame too, since the low level format absolutely went fantastic! Drives were perfectly usable, I managed to get files working on there and there were no clicking symptoms.
    Does your ST-01 have a bios chip? From what I recall, we used an ST-01 when building a hard drive card for our 30-286 and it did not have a bios and would only recognize a hard drive.
    The other drive to try would be a Syquest 44 or 88 drive as they were able to act as a boot drive in our 486 with a Future Domain controller with a bios.
    It does! Thanks for asking, it's a late variant with the v3.2 BIOS that supports non-Seagate drives.
    Quote Originally Posted by Kazblox View Post
    That's very cool. I think we had a 1.01 BIOS from an ST-02. Now that I think about it, we have quite a few SCSI cards we bought with drives just in case the drive wouldn't work with our Future Domain. These are all probably brand new in their packaging. It will be fun to find them and enjoy the memories.
    1,098
    Quote Originally Posted by 2icebitn View Post
    External ZIP SCSI drives could be set to ID 5 or 6. You can't use ID 7 because that's reserved for the SCSI controller.
    It is possible to make a bootable ZIP disk for 68k macs if you format the disk with the Mac version of Iomega's ZIP tools. I remember being able to boot a few crackerbox macs I had in the past from an external ZIP drive. Formatting a ZIP disk in the finder and moving over the system tools usually won't work, especially if it was a PC formatted ZIP disk.
